Oil pump for an OBD0 B16?
Old Apr 26, 2006 | 04:15 AM
TurboEM1's Avatar
Default Oil pump for an OBD0 B16?
Hey guys I have a b16a in my crx and need a new oil pump. Is there any difference between the years and if so which one do i use?
Also how hard is the install with engine out of the car? Any write ups? Thanks
Old Apr 26, 2006 | 04:18 AM
YasRex's Avatar
Default Re: Oil pump for an OBD0 B16? (TurboEM1)
I don't think there is a big difference but I would stick with the pump for your engine.
Install is really easy. Check your service manual.
Old Apr 26, 2006 | 04:52 AM
crxnj's Avatar
Default Re: Oil pump for an OBD0 B16? (YasRex)
you need a dohc vtec oil pump..engine is out of the car it should be very easy,,just make sure to get a good manual..
just order a pump for a 92-93 integra gsr,,or del sol b16a3,,etc..
Old Apr 26, 2006 | 10:45 AM
TurboEM1's Avatar
Default Re: Oil pump for an OBD0 B16? (Mr.speaker)
so i am assuming any b series will work. Like gsr, type r, del sol vtec, 99-00 civic si, ect..?
I thought i read somehwere that depending you will have to change the timing belt cover on the bottom bc they are different from obd0-1- and 2. Any info on that?
Old Apr 26, 2006 | 01:41 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">
I thought i read somehwere that depending you will have to change the timing belt cover on the bottom bc they are different from obd0-1- and 2. Any info on that?</TD></TR></TABLE>
Yes you're correct. The obd-2 pumps are different due to the crank sensor, but i wanna say the OBD-1 and OBD-0 pumps share the same covers. So a 92-93 Integra GSR pump should work fine for you.
Old Apr 26, 2006 | 04:07 PM
Nisif's Avatar
Yeah if you use an OBD 2 oil pump you'll have to mod your lower t-belt cover, I just took a dremel to mine and it worked out fine. Btw, Check your im, I have a brand new oem itr one for sale.
Cody Pereira
Sep 5, 2012 07:32 AM
camal
Jul 22, 2011 09:04 PM
1 sick ek9
Dec 9, 2006 09:31 AM
idriveadelsol7
25
Dec 9, 2005 08:47 PM
