newbi question
Old Apr 8, 2002 | 05:10 PM
integrx's Avatar
New User
Default newbi question
when i install i have to remove the water hose and this other hose, what is a good way to get the hose lose? i've tried pulling on it but it won't come off. so i used a wrench to twist it, but at the same time i'm damnanging the hose, so i wanted to know how you guys remove these hoses for the car.
Old Apr 8, 2002 | 06:52 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: newbi question (integrx)
When you install what? A water hose?
Old Apr 8, 2002 | 07:06 PM
tinkerbell's Avatar
Default Re: newbi question (B18C-EJ1)
wrap it in a cloth and try griping it with pliers and gently twist whilst pulling on a slight angle...
HTH,
t..
Old Apr 8, 2002 | 07:20 PM
kb58's Avatar
Banned
Default Re: newbi question (tinkerbell)
when replacing the hose(s), spray silicon spray in the end so you can remove it next time. (thanks to Carrol Smith)
rainforest's Avatar
tinkerbel is right but try screwdriver also on the hose.
Old Apr 8, 2002 | 07:21 PM
tinkerbell's Avatar
Default Re: newbi question (kb58)
and use worm screw type clamps!!!
lovehonda03
Oct 20, 2010 09:12 PM
Ramirez428
Mar 25, 2008 08:39 PM
Hondatuner88
Welding / Fabrication
Feb 13, 2008 06:56 PM
huge230
Nov 27, 2007 11:49 AM
Andrew 825SM
Oct 28, 2002 02:31 PM
