My b16 wont start. Need some advice..bad.
Old Apr 8, 2002 | 04:39 PM
Hayate42's Avatar
Default My b16 wont start. Need some advice..bad.
Ok here's the deal I swapped a b16 this weekend, I have a 1990 LS and swaped in a JDM b16, I added the 4 wires and the ground. It started idled fine but when I rev it past 3 it just shuts off then will not restart for like hours? Any ideas? Anyone have this problem? I checked and I have spark. Don't know how to check for fuel? Any ideas would be appreciated. Thanks for the input I"m really at a loss here...
Dan Cole
Old Apr 10, 2002 | 08:28 AM
Hayate42's Avatar
Default Re: My b16 wont start. Need some advice..bad. (Hayate42)
come on anyone?
Old Apr 10, 2002 | 08:40 AM
taqman15's Avatar
check your fuses....maybe you blew one
Old Apr 10, 2002 | 09:11 AM
rainforest's Avatar
Default Re: My b16 wont start. Need some advice..bad. (taqman15)
recheck grounds soetimes it will work for a littl then stop if its a ground
Old Apr 10, 2002 | 09:17 AM
Brandon's Avatar
Life is Suffering
SCC had the same problem. They had a problem with the distributor. You should check it out.
Old Apr 10, 2002 | 11:39 AM
topspeed86's Avatar
check for spark fuel timing
Old Apr 10, 2002 | 11:40 AM
topspeed86's Avatar
crack up the return line or pull the fuel rail and prime the car
Old Apr 10, 2002 | 12:56 PM
Kamin's Avatar
Default Re: My b16 wont start. Need some advice..bad. (rainforest)
its a ground
check your engine and tranny ground wires.
Eric724
Apr 28, 2011 06:23 PM
kc_kc
16
Dec 3, 2010 06:02 AM
Vtecme92
11
Jun 17, 2006 04:13 AM
2k1_ITR_0736
Jan 27, 2003 06:01 PM
90_Civic_Hatch
10
Aug 9, 2002 11:05 AM
