Pin location of 02 Signal Wire for 01 integra?
Old Apr 8, 2002 | 04:25 PM
EJK's Avatar
EJK
New User
Default Pin location of 02 Signal Wire for 01 integra?
Guys happen to know what pin location this is at? trying to tap in my a/f fuel gauge to this wire. Did a search and could not find any..
thanks in advance
Old Apr 8, 2002 | 04:43 PM
Kataku2K3's Avatar
Default Re: Pin location of 02 Signal Wire for 01 integra? (SLPMDE01)
On a normal OBD 2 car, at least for the P72 and P73 ECU the pin you are looking for is D7. However I am not sure if OBD 2b has a different pin layout then just plain old OBD 2. The best way to check this would be to disconnect your primary O2 sensor and continuity test it back to the ECU. Hopefully it will tell you that D7 is your wire. Latez
Old Apr 9, 2002 | 09:34 AM
kenji's Avatar
25 Year Member
Default Re: Pin location of 02 Signal Wire for 01 integra? (JDMspecEG6)
JDMspecEG6 gave the correct info for a '96-'98 Integra.
But the original post asked for the location for a '01 Integra. On the '01 Integra the primary O2 sensor signal wire is at C16.
-kenji
accordianex
Feb 19, 2006 07:07 AM
stumbler
Feb 6, 2004 05:59 AM
Frankinfreak300
Sep 27, 2003 08:43 AM
FusionITR
Feb 28, 2002 11:50 PM
Flamenco-T
Jul 7, 2001 04:38 PM
