tranny problems
Old Apr 25, 2006 | 05:22 PM
Panoply's Avatar
Default tranny problems
i have a 92 accord and yesterday when i was driving i tried to make a turn and as i did the car drifted to a hault and sat there and only reved when i gave it gas. its an automatic so i don't have the first clue as to what is going on with it, can anyone give me any insight. btw i just had a shop redo the brakes and cv axles so i don't know if this might have anything to do with it. thanks.
Old Apr 25, 2006 | 06:37 PM
accord-pro's Avatar
Default Re: tranny problems (Panoply)
sounds like the axle popped out of the tranny..,, or broke,
i am willing to bet that they misinstalled the axle,,
Old Apr 25, 2006 | 06:58 PM
YeuEmMaiMai's Avatar
Default Re: tranny problems (accord-pro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-pro &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the axle popped out of the tranny..,, or broke,
i am willing to bet that they misinstalled the axle,,</TD></TR></TABLE>
or they installed the wrong one.... I'm going to have to go with A-P on this one.....
have you checked your trans fluid?
Old Apr 25, 2006 | 09:05 PM
Panoply's Avatar
Default Re: tranny problems (YeuEmMaiMai)
not yet, this just happened yesterday, and i had to get it towed back home. i guess ill take it apart and see if i can see something. if the axle was popped out of the tranny would it literally be lying there? or does it stay put, yet not rotate with the tranny? i will also take a look at the tranny fluid. thanks you two.
Old Apr 25, 2006 | 09:22 PM
it may not be laying there because it pulled out just far enough to cause the car to stop moving
Old Apr 25, 2006 | 09:36 PM
Panoply's Avatar
alright thanks man, ill try to check that out as well. thanks.
Old Apr 25, 2006 | 09:40 PM
Panoply's Avatar
as far as the axles go, are the auto and manual axles different. i don't know if some accords come without abs, but this model has it, are the axles different from abs to non-abs?
Old Apr 25, 2006 | 09:50 PM
I believe they are the same but I am not sure as I never had someone ask me if my 94 has abs when inquiring about axles.....(passenger side one is due soon
Old Apr 25, 2006 | 09:57 PM
Panoply's Avatar
however manual and auto are? i thought they were, however i could be wrong.
SP GARAGE
Jan 15, 2012 05:32 PM
Honda_Accord
Aug 16, 2009 06:45 PM
RevTek 6
Nov 28, 2007 03:46 AM
BONGFIRE420
24
Oct 6, 2007 12:10 PM
EJ1 wilcox
Jun 21, 2004 10:46 AM
