Track Gurus...Best launching?
warm them up really good and rev to 4500 and drop it. if you do ok keep reving higher till you spin too much. you pretty much have to practice and see what works for you. good luck.
With the nitto drag radials use tire pressures from 18-22psi, launch from 4500-5500..all dependent upon track condition and what psi you have in the tires...with nitto's and icebox I was at 14.37, 2.2 60ft.
Austin
Austin
2.151 60' on Potenza SO-3's. Rev it high and ride the clutch, just figure out the proper balance of wheelspin, but don't be afraid to tach it on up. When I mean ride it I don't mean for 5 minutes either just enough to get that little pull in your back without to much wheelspin.
What about the best tire pressure for stock ITR rubbers...I know they suck, infact there pretty hard to hook at anything abouve 3000 but I need some help here..I tried 20psi...but it didn't make much difference.
The best thing to do is learn your car. I run 1.9 60 fts on a 205/40/17 BFG drag t/a's at 15psi. I rev the car to about 5000 rpm and come out hard using the clutch to control wheel spin until the car hooks. Again the best thing to do is practice.
Mattj
Mattj
I get 2.0's with BFGoodrich G-Force drag radials....
I play with the throttle from 2500-3500 and ride it out a tad.
Run 16-18 PSI. Minimal spin and grabs awesome. Unfortunately, the Nitto DR's are not as stickky as the BFG's. I have both and the BFG's are WAY better. The Nittos are more comparable to the old BFG comp ta drag radials.
Good Luck, maybe I will see you at E-Town sometime, I go there all the time
Miguel
Miguel
how long do you inticipate the bfg's to last?
Mattj
Chip398193
Mar 4, 2002 08:25 AM
boost killz
Jul 19, 2001 07:11 AM
