how to remove panel that houses the climate control
Old Apr 25, 2006 | 07:58 AM
powersteer's Avatar
Default how to remove panel that houses the climate control
hey guy,
i'm trying to remove the center panel on the console. tried to remove the hazard and demister button 1st as according to manual, but they cldnt come off. i didnt dare to apply too much force as i'm worried that i might break them
am i doing the right steps?
pls advice
Old Apr 25, 2006 | 08:01 AM
infulleffect's Avatar
Default Re: how to remove panel that houses the climate control (powersteer)
use a flat head screw driver and gently pry from the bottom of the HAZ and rear defrost switch...they will come out. There is a pressure tab on each side of the switch...once they are out, you'll see two screws...don't forget to disconnect the cable on the passenger side that connects to the heater core.
Cheers
AznBlueBoy
Jun 13, 2011 03:47 PM
hondaon18's
13
Dec 26, 2008 06:12 AM
ner0x
Jun 23, 2005 07:17 PM
GreenTeaLS
Mar 30, 2005 09:51 AM
EKtypeRhaTcH
Jul 8, 2003 10:55 AM
