how do u take off tint?
i heard of alot of ways to take it off, but i wanna know a way that would actually help? would heating the window with a iron through a paper bag work? or do i have to do it the hard way with a razor blade and soap? any advice would be great. peace
I tried the razor blade thing and it was horrible. I ended up getting the first layer off and the second layer was a bitch..
The best way I found was to get some goo remover of some sort, or even Windex. spray it on the window generously then cover with a plastic garbage bag. Let it soak for a while, in the sun if possible. Then remove the bag and you should be able to get a corner up using a blade then peel it off quite easily.
gl
gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kind_of_a_big_deal »</TD></TR><TR><TD CLASS="quote">steam </TD></TR></TABLE>
If you have a steamer that will make the tint and glue just fall off. Other than that you are stuck with hours of endless scraping with a fazor blade. Good luck man
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94~GSR »</TD></TR><TR><TD CLASS="quote">ill say get a goo gone or just soak it up with soap, and have a lot of Razor cause u will need it.....</TD></TR></TABLE>
steam and you will not have cuts or sore fingers and it will take about half the time and effort. I promise.
expletive man when i took my tint off my other car it was a BIOTCH TO TAKE OFF
what i had to do was use 5 n yes i said 5 razor blades and this tint remover spray that i got from a near by auto parts store. it took my and my gf 3 days to take all that crap off with about 4 hours a day of scraping. oh n i had a crx b4 and that shiet was a small car so there wasnt even that much tint but still took a long time. so hpoefully somone one here has a good way to take it off. GOOD LUCK
EVERYONE STOP USING RAZOR BLADES!!!!
THERES AN EASY WAY TO REMOVE TINT!!!!!!
ok this is how you do it... you can literally take off tint like in one piece.
There are two good methods for removing tint. Steam (if your rich) and........... amonia(if your financially impaired).
go to the store and buy pure amonia. put it in a spray bottle. now get some big plastic bags like those black ones and cut it so its in nice big sheets. now spray the window you want to remove the tint from with lots of amonia nice and wet. then put amonia on one of the plastic bag sheets and lay it up against the window. cover up the entire window and make sure its still wet inbetween the plastic bag and the glass. let it sit in the sun and bake for like an hour. if you need to go back and apply more amonia then do so..
after the hour take off the bag. sometimes the tint will come off with the bag sometimes it wont. most likely it wont so just use a razor blade to peel up one of the corners of the tint and pull on the tint with your hands and it should start pulling off the window pretty easily and cleanly.... as you pull it might rip so just keep using a razor blade to lift up a corner and pull some more.... if you did it right you can get an entire window untinted in like one piece! but usually it comes off in like 2 or 3 big pieces....
anyways i took off my tint this way and it worked great. when your done use soap and water to clean the windows cause if your gona get it re tinted the new tint will have trouble staying on if you still have amonia on your windows.
I only had the tint on my hatch on my DA and I had my girlfriend sit in the hatch with a razorblade and me on the outside with my sick wagner heat gun and it took us a couple hours.
i spray the inside of the window with glass cleaner and use a heat gun on the outside of the window and as it is heating the glass pull lightly on the tint and it takes it all off ..i did 2 windows last night like this and i got 6 more windows tonight to do .... or you can go to kragen and buy tint off i like that stuff because it doesent smell bad
i_VTEC
Jun 30, 2007 05:33 AM
