stainless steel brake lines?
Old Apr 8, 2002 | 01:46 PM
beeboyee's Avatar
Default stainless steel brake lines?
where to buy them
and what are the best kind?
i think its time to replace the stock ones
Old Apr 8, 2002 | 01:57 PM
Ponyboy's Avatar
Painting Masterpieces
Default Re: stainless steel brake lines? (beeboyee)
Goodridge. The kind that have plastic over the steel. About $100 bucks. All the performance stores have them and Goodridge can locate a dealer for you.
Old Apr 8, 2002 | 03:16 PM
voltronR34's Avatar
I got mine @ 1320 Motorsports in San Marcos Ca.
No doubt Importparts will have what you need.
Some synthectic brake fluid would be a good idea while you will be doing it anyway. I use the motul 600 something like 10 bucks a bottle ( 500ml ) 2 bottles will do the job.
Old Apr 8, 2002 | 03:31 PM
Gennady's Avatar
New User
Anyone ever use Stillen lines?
Old Apr 8, 2002 | 06:58 PM
Padronis's Avatar
Default Re: stainless steel brake lines? (Wont be beat)
These won't really do much for you unless your car is old, and the lines are getting worn. If you do buy them, get Goodridge and check them every now and them to make sure they aren't rubbing against anything rough. Buy the ones that are coated so dirt doesn't destroy them.
Old Apr 8, 2002 | 10:19 PM
Gennady's Avatar
New User
Default Re: stainless steel brake lines? (G2LSS)
I mean Stillen SS lines. They have to be an improvement simply due to the fact that they wont flex as much as the stock rubber ones.
Old Apr 8, 2002 | 11:25 PM
beeboyee's Avatar
cool thanks, anything else i would need to knoe?
im intalling them in a 92 civic si
Old Apr 8, 2002 | 11:53 PM
Charles B.'s Avatar
I got mines for $1oo from Brian at Fastbrakes. I don't even know what brand they are but they got the plastic lining over the steel.
If you want a cheaper alternative to SS brake lines, you go the zip-tie route, but that's a different topic.
Skatnshawn
Suspension & Brakes
13
Mar 8, 2013 03:24 PM
itellyawhat
17
Nov 27, 2007 10:44 PM
Mike D
20
Dec 17, 2004 06:13 AM
phantom_sol
Sep 30, 2003 07:01 AM
PupaScoopa
Jul 23, 2003 02:38 PM
