LS Crank and Pistons in B16 block?
Old Apr 24, 2006 | 06:38 PM
CO_CReX's Avatar
Default LS Crank and Pistons in B16 block?
I have a quick question. I have a B16 and Im wondering if I can use an LS crank with the LS pistons and rods in my B16? Will it fit and work fine? Only reason I ask is because I found all those parts for really cheap. Thanks guys.
Old Apr 24, 2006 | 07:52 PM
Ruben19's Avatar
nope.
stroke is longer.
You may want to try the b17 crank
Old Apr 25, 2006 | 05:37 PM
mmuller's Avatar
Mad Scientist
Default Re: LS Crank and Pistons in B16 block? (CO_CReX)
you gonna have to use custom raised pin pistons.
someone here on H-T makes them..Cant remember
Old Apr 25, 2006 | 09:24 PM
WhiteNess's Avatar
Default Re: LS Crank and Pistons in B16 block? (mmuller)
Correct me if i'm wrong...and I don't wanna give any wrong advice but couldn't you use LS crank, b16 rods, LS pistons?????
Old Apr 26, 2006 | 03:56 PM
mmuller's Avatar
Mad Scientist
Default Re: LS Crank and Pistons in B16 block? (WhiteNess)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteNess &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if i'm wrong...and I don't wanna give any wrong advice but couldn't you use LS crank, b16 rods, LS pistons?????</TD></TR></TABLE>
nope.
stroke is different, needing different lenght rods.
b16 block is also shorter than the b18.
Old Apr 26, 2006 | 11:03 PM
WhiteNess's Avatar
thats what I always thought but was never 100% sure...thanks for the clear up
CTR_B
Nov 9, 2008 05:54 PM
CTR_B
Oct 17, 2008 04:19 PM
GumballNA
Aug 5, 2004 02:49 PM
94tegra
Jan 26, 2004 12:16 PM
wm5holla
May 6, 2003 09:27 AM
