Intake Air Temperature (IAT) Sensor Circuit High Voltage
Old Apr 24, 2006 | 06:17 PM
Civic_JDMx98's Avatar
Default Intake Air Temperature (IAT) Sensor Circuit High Voltage
i got a problem with my car.. engine knock... so i go ahead n use my code reader and it show p0113 which is Intake Air Temperature (IAT) Sensor Circuit High Voltage.... Does that mean my temperature sensor is broken?? i should get a new one??
Old Apr 24, 2006 | 06:21 PM
sicones's Avatar
Default Re: Intake Air Temperature (IAT) Sensor Circuit High Voltage (Civic_JDMx98)
check the wires for continuity, get a DMM check the resistance of the temp sensor, it says it in the helms manual, or just buy a new sensor
Old Apr 26, 2006 | 09:36 PM
Default Re: Intake Air Temperature (sicones)
found the problem.. it was my 8mm spark wires. my cylinder 1 and 2 was misfiring. so basiclly i was running only 2 cylinder.. lol.. put bak my stock wire.. it ran fine now..
castle1313
Feb 4, 2010 03:56 PM
K i l l a B e e.
Jan 2, 2008 01:32 PM
Hittnthebz
Mar 17, 2007 11:45 AM
