Intake Air Temperature (IAT) Sensor Circuit High Voltage
i got a problem with my car.. engine knock... so i go ahead n use my code reader and it show p0113 which is Intake Air Temperature (IAT) Sensor Circuit High Voltage.... Does that mean my temperature sensor is broken?? i should get a new one??
Re: Intake Air Temperature (IAT) Sensor Circuit High Voltage (Civic_JDMx98)
check the wires for continuity, get a DMM check the resistance of the temp sensor, it says it in the helms manual, or just buy a new sensor
Re: Intake Air Temperature (sicones)
found the problem.. it was my 8mm spark wires. my cylinder 1 and 2 was misfiring. so basiclly i was running only 2 cylinder.. lol.. put bak my stock wire.. it ran fine now..
