Starter cable assy. caught on fire?? WTH!
Old Apr 24, 2006 | 06:09 PM
f2m0u5's Avatar
Default Starter cable assy. caught on fire?? WTH!
Modified by 0LlY at 6:35 PM 4/25/2006
Old Apr 24, 2006 | 06:18 PM
sicones's Avatar
Default Re: Starter cable assy. caught on fire?? WTH! (0LlY)
any of the wires rubbing on metal could have caused the insulation to fray and short to ground, I bet when you did the engine swap the wires were probibly just hanging around and not properly secured
Old Apr 24, 2006 | 06:21 PM
f2m0u5's Avatar
Default Re: Starter cable assy. caught on fire?? WTH! (sicones)
Actually they were properply secured, they might have been rubbing though. I wish I left the wires on so I can check to see if they were. Do you think I need to buy a new starter?
Old Apr 25, 2006 | 05:31 AM
sicones's Avatar
take it out of the car and test it, get some jumper cables clip the negative one to the body of the starter and touch the positive one to the nut the heavy gauge wire connects
Old Apr 25, 2006 | 10:55 AM
f2m0u5's Avatar
Yea I will hopefully I can do it today, real busy with other stuff. Thanks for the help, but do you think it could have damaged anything else? None of my fuses popped either, so I'm guessing everything else might be fine.
G60
Dec 29, 2006 10:24 AM
ShagPower
Aug 31, 2006 07:12 AM
f2m0u5
Apr 24, 2006 09:52 PM
rex_racer728
24
Feb 3, 2006 10:57 AM
sLoWrAcEr
Apr 19, 2005 08:34 PM
