How do I get the !@%% exhaust housing bolts off?
Old Apr 8, 2002 | 12:59 PM
Sonny's Avatar
Default How do I get the !@%% exhaust housing bolts off?
How do I get these bolts off? I tried soaking them in liquid-wrench, but man, they are on there real tight. I already bent down the retaining clamps, so they are not in the way. I am afraid to put too much force on them for fear of breaking them.
Is a torch in my future?
Thanks,
Sonny
Old Apr 8, 2002 | 01:04 PM
racerxadam's Avatar
Default Re: How do I get the !@%% exhaust housing bolts off? (Sonnyballs)
yes it sounds like a torch is in your future. heat the housing where the bolts go in and i personally would use a six point wrench and once they start loosening up keep wiggling back and forth.
Old Apr 8, 2002 | 01:12 PM
93LSivic's Avatar
Dude, theres lock tabs on there. I hope that you noticed this, if not then you gotta bend them down then take the bolts off.
If you did that, then hit them with penetrating lubricant and let it sit for a while.
Might wanna try hitting them with a torch also.
Old Apr 8, 2002 | 01:15 PM
Sonny's Avatar
Default Re: How do I get the !@%% exhaust housing bolts off? (93LSivic)
Did you see the first sentence in my original post? Yeah, don't worry...saw the lock tabs and moved them outta the way. Man...anything associated with exhaust is always a pain in the *** to take apart.
Sonny
Old Apr 8, 2002 | 01:17 PM
DLB1994's Avatar
get a 13 mm open and close end wrench with the 6point close end
13mm fit better then a 1/2 inch
Old Apr 8, 2002 | 01:20 PM
intekragsr's Avatar
Default Re: How do I get the !@%% exhaust housing bolts off? (DLB1994)
maybe a vise grip and a hammer???
20CiviC02Si
Mar 30, 2015 08:03 PM
dkrex001
Oct 15, 2008 06:24 AM
pliskin679
Sep 14, 2007 06:57 PM
White V6
Aug 3, 2005 08:19 AM
