Syncro Replacement
my gsr tranny has a 3rd gear grind and i just wanted to know if i have to replace just the 3rd gear syncro or do i have to replace the gear too. i would like to get the gearspeed carbon coated ones but dont know if i need to get the gearset also. can the gear even get damaged or just the syncro.
also if i end up not doing this for a little while will it hurt anything else in the tranny besides the syncro and maybe the gear.
Modified by GBPDC2 at 9:11 PM 4/24/2006
check to see if the engadgement teeth on your 3rd gear are rounded off. if they are which more than likly they are replace the gear to. if you dont have time to tear down the tranny then order parts i would just order the gear anyways . most time the gear teeth are as bad as the syncro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YasRex »</TD></TR><TR><TD CLASS="quote">About $200 bucks will do all the syncros I think. </TD></TR></TABLE>
Yep, I think thats how much my 3-4-5 carbon coated syncros were from gear-speed..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest »</TD></TR><TR><TD CLASS="quote">check to see if the engadgement teeth on your 3rd gear are rounded off. if they are which more than likly they are replace the gear to.</TD></TR></TABLE>
And if the engagement teeth are worn, there is a good chance the slider is, too.
I did mine recently. Had third gear grind, change 1-5sync from gearspeed 275. It fixed third but 2nd is still jack from bad sleave and hub do to a broken clutch disk spring that broke(all down shift grind).
iBrandon
Aug 23, 2007 12:17 AM
HondaRcB
Nov 24, 2006 11:41 AM
