headgasket or what? HELP needed ASAP
Old Apr 24, 2006 | 03:17 PM
SLO Sol's Avatar
Default headgasket or what? HELP needed ASAP
1-150
2-150
3-30
4-30
could it be the head gasket? or what else could it be?
Old Apr 24, 2006 | 03:41 PM
I3ooS710's Avatar
Default Re: headgasket or what? HELP needed ASAP (D-money 92si)
Headgasket, pistons, ringlands, fucked up valves... There are a lot to take into consideration.
How does it feel when/if you drive it?
Old Apr 24, 2006 | 08:07 PM
SLO Sol's Avatar
she idles rough enough that if im not in the throttle she dies... alot of smoke comes out too. thats why i think its the headgasket... dont want to put a bunch of money into a possibly blown motor if i dont have to
Old Apr 24, 2006 | 08:16 PM
1cleangsr's Avatar
I'd pull the head to start off with and see what's going on with the pistons/and rings. Did you run it hard before it started happening?
Old Apr 24, 2006 | 08:18 PM
SLO Sol's Avatar
Default Re: headgasket or what? HELP needed ASAP (1cleangsr)
it was raining that night and i had bald tires so yeah i was playin in a parking lot
Old Apr 24, 2006 | 08:47 PM
redhondacivic's Avatar
Look at the coolant and check the oil they should be like "milky" chocolate milk .
Old Apr 24, 2006 | 09:57 PM
E46Kid's Avatar
Default Re: headgasket or what? HELP needed ASAP (redhondacivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redhondacivic &raquo;</TD></TR><TR><TD CLASS="quote">Look at the coolant and check the oil they should be like "milky" chocolate milk .</TD></TR></TABLE>
sign of the headgasket going out
Old Apr 25, 2006 | 12:32 AM
Nahf0o's Avatar
drop oil into ur bad pistons and do the compression test again. if it holds compression then it means ur rings are bad. i dont think its a headgasket though.. u might have blown pistons or bad rings
Old Apr 25, 2006 | 10:00 PM
SLO Sol's Avatar
my friend held a peice of paper to the tail pipe and alot of oil came out today when she fired possible valveseals bad too
Old Apr 25, 2006 | 10:32 PM
ZipTieGUy's Avatar
playing in the rain eh maybe you bent some valves when you sucked in water
.adam.
Apr 16, 2006 10:57 PM
baboonstyle
18
Nov 11, 2005 04:02 PM
turbo_b16_ex
12
Oct 6, 2005 01:17 PM
vultron
Dec 3, 2003 10:24 PM
whoa its len 2
May 19, 2003 12:20 PM
