Vacum lines WHERE???
i know where some vacum lines are but i don't know which ones to check for leaks since i have the idle problem. checked everything els, check cleaned IACV, FITV, check and bleed coolant, replaced tb gasket nothing worked. i did try to look for vacum leaks but don't know where to start. someone Please help cause i asked lots of times and no one seems to know the problem. everyone tells me its the stuff i listed above. but not in this case cause all the stuff above is in good working order. like i said maybe its just a vacum line i couldn't get to. but can someone please tell me or give me a draw up of where all the vacum lines are that might affect my idle problem??? the idle goes up and down when cold then is fine when warm. plus i have a 94 dx manual stock.
no lights. hahhaha i know all the vaccum lines are under my hood. where els would they be. i want to know which ones are vacum lines??? the line connecting what to what is a vaccum line?
i need some help cause im gona be going on a road trip and dont want this on my mind. plus i dont think its doing any good for my mpg or my engine. OR IS MY BEST BET JUST TAKING IT TO HONDA?
