Idk if this is a nooby question or not.
Old Apr 23, 2006 | 10:07 PM
Usdmowns's Avatar
Default Idk if this is a nooby question or not.
Hey guys I m doing a d16z6 swap in my rex and Im turboing it to I have a air research 42 trim turbo. thats wastegated at 8 psi . I was wondering what can the stock z6 internals handle as in how much boost. Ive heard the z6 connecting rods are farily weak. thanks guys
Old Apr 23, 2006 | 10:10 PM
YasRex's Avatar
Default Re: Idk if this is a nooby question or not. (WideBody96)
You can put in 400 psi or however much you want.
Its simply the power output that the engine can/cannot handle.
How much power can the stock engine handle? around 175-200 hp/tq
Old Apr 23, 2006 | 10:11 PM
crxnj's Avatar
with the stock map sensor you can only boost about 10-11psi..Id say a safe number on that engine is around 200-225whp with good tuning..However recently a tuner got one to make over 300whp on the dyno,,and set it at 250whp for the street and it lasted..
Old Apr 23, 2006 | 10:17 PM
Usdmowns's Avatar
damn I bet that had to be a good tune than. but you would say 8 psi daily would be good than.
what do yuo think about 10psi at the track?
Old Apr 23, 2006 | 10:20 PM
crxnj's Avatar
Default Re: (WideBody96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WideBody96 &raquo;</TD></TR><TR><TD CLASS="quote">damn I bet that had to be a good tune than. but you would say 8 psi daily would be good than.
what do yuo think about 10psi at the track?</TD></TR></TABLE>
You're focusing on the wrong part..You need to worry about the HP level..Im not sure what the hp level would be at 8psi and 10psi for your turbo..
Old Apr 23, 2006 | 10:42 PM
Usdmowns's Avatar
so I should put it at 8 psi and dyno it to see what that is and go fromt here?
Old Apr 23, 2006 | 10:56 PM
crxnj's Avatar
Basically yeah,,
Old Apr 23, 2006 | 11:31 PM
Usdmowns's Avatar
ok thanks man
vtec-boy17
Engine Management and Tuning
May 14, 2009 04:24 AM
hold your breath
May 10, 2007 09:34 PM
hany
Nov 13, 2006 03:53 PM
ekslax
Dec 27, 2005 09:39 PM
blueintegra
Aug 31, 2005 02:31 PM
