would only having 2 bolt holding on my dizzy cause a slight misfire at idle?
Old Apr 23, 2006 | 09:08 PM
the.hamburglar's Avatar
Default would only having 2 bolt holding on my dizzy cause a slight misfire at idle?
up
Old Apr 23, 2006 | 09:41 PM
Stripped Honda's Avatar
99-0104
Default Re: would only having 2 bolt holding on my dizzy cause a slight misfire at idle? (the.hamburglar)
no
Old Apr 23, 2006 | 09:47 PM
Default Re: would only having 2 bolt holding on my dizzy cause a slight misfire at idle? (Stripped Honda)
well i just tried it and it must have done something because it idles way better and the miss is almost gone. it must not have be aligned in there perfectly w/ 2 bolts
Old Apr 23, 2006 | 11:00 PM
NineTwoSi's Avatar
What kind of spark plugs are you using? And my dizzy was being held on by 1 bolt before and it was fine. I'm not an idiot, I didn't know until I went to change the o-ring because i was leaking oil and found out at that point. I don't knowingly run around with 1/3 of the bolts I need.
Old Apr 23, 2006 | 11:03 PM
Schrader's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">well i just tried it and it must have done something because it idles way better and the miss is almost gone. it must not have be aligned in there perfectly w/ 2 bolts </TD></TR></TABLE>
Yeah without that third bolt, the dizzy may have moved around
Old Apr 24, 2006 | 12:47 AM
wez's Avatar
wez
if it moved round though there is no way it would course it to misfire. it has a little movement when the three bolts are losened to allow for fine tuning the timing. If the cars misfing you want the dizzy, leads and plugs. If you still have no luck check the timing.
Old Apr 24, 2006 | 06:40 PM
Default Re: (wez)
did that all, nothing. i really need this gone. and cold start is rank
401B18TEG
May 22, 2008 07:30 PM
A.E Motoring
Jan 5, 2006 08:42 PM
Matgallis
Aug 25, 2004 02:36 PM
Layziebtnh055
May 14, 2004 06:42 AM
Mikey
Apr 25, 2003 08:47 PM
