HELP PLEASE!!!! Clutch HELP....
Old Apr 23, 2006 | 08:09 PM
SpOoLiNg CiViC's Avatar
Default HELP PLEASE!!!! Clutch HELP....
ok... after running at the track... i drove around fine.. went to sonic and after i left my clutch went all the way down like it should "disengage " but when i came up with it.. about 1inch or not even it "engages".... and i had to pump it a few times after i put it in neutral...... so i looked over it today.... i seen that the master clutch cylender had some stuff comming out... i went to advanceautoparts got a new one... relpaced it... bleed the clutch line to get all the air out.... still same thing..??? what should i do? .... i mean i pump it a few times and it goes into gear and goes.. so i dont think it's the clutch.....
HELP PLEASE!
Thanks guys!!!!!! for ur help... honda-tech is always there
Old Apr 23, 2006 | 08:53 PM
Default Re: HELP PLEASE!!!! Clutch HELP.... (SpOoLiNg CiViC)
anyone know?
Old Apr 23, 2006 | 09:00 PM
CBEengineering's Avatar
check the slave and inside bellhousing might be leaking
Old Apr 23, 2006 | 09:07 PM
Default Re: HELP PLEASE!!!! Clutch HELP.... (CBEengineering)
thanks.. i'll look at slave tomm... it's just like it does not have any pressure... weird!
Old Apr 24, 2006 | 06:39 PM
i checked SLAVE... looks good.... dunno what else to check or where.. i dont see any fluid anywhere.... it's just like it's not getting any pressure.... clutch is fine... just dont know what the hell the problem is....
Old Apr 24, 2006 | 07:25 PM
unhook clutch line at slave and MC blow out line w compressed air
might be something stuck in there you said there was something coming out of MC so it could be backed up there
other than that if everything is fine then i dunno
Old Apr 25, 2006 | 05:15 AM
damn should have thought of that... yeah it was like solid "gunk".... man this **** is pissing me off.....
thanks for help.. will go out there today..
if anyone knows anything else... help me out... it's like i just dont have any pressure when i push the cluch down anymore.... ??????
Old Apr 27, 2006 | 06:53 PM
b16ner's Avatar
hey i had the same thing in my 92 si..... i had some gunk in the line and my cylinder cap seal was letting air in and wasnt causing a vaccum. I flushed the line and got a new cap and now it works just fine. check it out
Old Apr 27, 2006 | 06:58 PM
Wannabe JDM's Avatar
if its not gunk check for leaks in the lines.
Old Apr 27, 2006 | 08:29 PM
Default Re: (slowej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowej &raquo;</TD></TR><TR><TD CLASS="quote">if its not gunk check for leaks in the lines. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spOoliNg CiViC &raquo;</TD></TR><TR><TD CLASS="quote">i checked SLAVE... looks good.... dunno what else to check or where.. i dont see any fluid anywhere.... it's just like it's not getting any pressure.... clutch is fine... just dont know what the hell the problem is....
hmmmmm
MTracing
Transmission & Drivetrain
Jan 10, 2012 11:27 AM
cockeyedcricket
Sep 25, 2009 12:48 PM
integragsssr
Feb 6, 2009 08:54 PM
flatblackintegragsr
Mar 31, 2006 08:23 PM
NoBottleJustThrottle
Jan 22, 2005 10:22 AM
