axle seal leakng after axle swap
Old Apr 23, 2006 | 03:38 PM
dewoine's Avatar
Default axle seal leakng after axle swap
well i recently replace my driver side axle. Went to drive it for awhile came back and parked . well i came back out then there was a puddle of tranny fluid. so we took it back out again to inspect and the seal was pushed in deep so we took it out and sat it flushed against the tranny like the manual says put everything back and it seems like it fixed it. well woke up this mournin and theres another puddle again . pulled it out again and bought a new seal but this one didnt have that lil circle spring ring with it ..is the that part needed wit ha aftermarket seal or is it that sombody didnt package it at the auto store?
plus would there be anything else that would make it leak. never had this problem before
setup is :
d15b vtec
dx tranny 5spd
Old Apr 23, 2006 | 04:20 PM
dewoine's Avatar
Default Re: axle seal leakng after axle swap (dewoine)
bump before work
im confused about this s#@t
Old Apr 23, 2006 | 05:32 PM
Mista Bone's Avatar
D Tranny Guru
need the spring to seal the seal
Old Apr 23, 2006 | 06:01 PM
JdMeF9SiR2's Avatar
Default Re:
Get another seal and when u put it in this time, make sure it sits flush with the housing. ( push the seal in just far enough that the seal goes in, not deep in there. Pm me if u don't understand
Old Apr 24, 2006 | 05:32 AM
dewoine's Avatar
Default Re: Re: (JdMeF9SiR2)
thanks for da replies ..this **** just been pissing me off because its my way to and from work. well i guess i will be going back to the auto parts store for another one and making sure it has all the necessary parts with it this time. hopfully everything works out and no more leaks
Old Apr 24, 2006 | 07:08 AM
nocturnaldragon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMeF9SiR2 &raquo;</TD></TR><TR><TD CLASS="quote">Get another seal and when u put it in this time, make sure it sits flush with the housing. ( push the seal in just far enough that the seal goes in, not deep in there. Pm me if u don't understand</TD></TR></TABLE>
Exactly, it took me a while to figure that out and one transmission later.
Old Apr 26, 2006 | 03:14 PM
dewoine's Avatar
Default Re: Re: (nocturnaldragon)
well a not so good update i bought a new seal again , put it in flush like the manual says and is still leaking
could i just have a bad cv axle becuase i didnt have this problem before i changed it. the deal is i have had different trannies in the car but the old cv axle never had a problem except being busted
Old Apr 27, 2006 | 04:32 AM
dewoine's Avatar
Default Re: Re: (dewoine)
bump
Old Apr 27, 2006 | 06:57 AM
tatmark1's Avatar
what brand is the seal? i would use only honda or timkin
Old Apr 29, 2006 | 11:31 AM
dewoine's Avatar
Default Re: (tatmark1)
well im really thinkin its not the seal im starting to believe its the cv axle becuase i my old axle did nt leak or anything soon i do a basic axle change i have a leak with the NEW axle. im just wondering how they could mess on giving me the wrong axle becuase its fits perfect
pjr710
Apr 6, 2009 02:05 PM
civicjoe8
Apr 11, 2006 08:52 PM
jimbeamsEK
Apr 1, 2005 08:46 PM
Blaze45
Apr 20, 2004 03:35 AM
NeoGSR
Apr 27, 2003 09:30 AM
