91 B16A -> 97 EX
Old Apr 23, 2006 | 02:18 PM
H2on0da3's Avatar
Default 91 B16A -> 97 EX
Hey everyone,
Very shortly, I plan on swapping a JDM B16A (91 CRX SI MOTOR) into my 97 Civic EX, currently running a D16Y8. I would like to get your feedback for ideas, advice or any issue you all have run into or that may arise when I perform the swap. So this is my story:
I plan on using an OBD0 -> OBD1 conversion harness with a 4 wire 02 sensor, and run a P28 (92-95 Civic) Ecu. I am curious if a crank sensor will be an issue, if so, how can I correct it. This is mainly what I am concerned about at the moment. Please let me know if I should worry about other things etc. Pretty much, let me know what your thoughts are about this swap.
I plan on doing this very soon so quick feedback is greatly appreciated. Thanx to all in advnace.
Old Apr 23, 2006 | 02:29 PM
SVOboy's Avatar
OBD1 doesn't see the crank speed fluctuation sensor or whatev, so no issue. Inside the car you need an obd2 to obd1 ecu harness though, not obd0 to obd1.
Old Apr 23, 2006 | 03:23 PM
H2on0da3's Avatar
Default Re: (SVOboy)
I see, so I need OBD2 -> OBD1 cause my cars OBD2, not OBD0 -> OBD1, cause of the motor is OBD0. Interesting, thanx for the help.
Anyone else have any experience with this swap? Let me know! Thanx!
Old Apr 23, 2006 | 09:26 PM
H2on0da3's Avatar
Default Re: (H2on0da3)
Anyone else got any feedback for me?
Old Apr 23, 2006 | 09:34 PM
sikciv666's Avatar
bump for a CT head
Old Apr 24, 2006 | 09:12 AM
H2on0da3's Avatar
Default Re: (sikciv666)
Ha thanx bro
Old Apr 25, 2006 | 05:58 AM
H2on0da3's Avatar
Anyone else have any input for me?
Old Apr 26, 2006 | 05:24 PM
H2on0da3's Avatar
Old Apr 26, 2006 | 05:30 PM
SuperSlow's Avatar
Default Re: 91 B16A -> 97 EX (H2on0da3)
tranny is cable.
also, make sure you don't have an obd0 engine going into your obd2 car.
Old Apr 26, 2006 | 05:48 PM
eg6ajk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2on0da3 &raquo;</TD></TR><TR><TD CLASS="quote">Hey everyone,
I plan on using an OBD0 -&gt; OBD1 conversion harness with a 4 wire 02 sensor, and run a P28 (92-95 Civic) Ecu. I am curious if a crank sensor will be an issue, if so, how can I correct it. This is mainly what I am concerned about at the moment. Please let me know if I should worry about other things etc. Pretty much, let me know what your thoughts are about this swap.
I plan on doing this very soon so quick feedback is greatly appreciated. Thanx to all in advnace. </TD></TR></TABLE>
88-91 crx si motor = d16a(6) defintaly not worth trouble swapping
if you mean 88-91 Civix/CRX SiR B16A OBDO = pita, unless you don't mind doing alot of, little upgrades to even work.
1) mounts not compatible will require a 99-00 si engine brackets + a/c mounts
depending on the tranny used you might require either hasport kit to stock b-series mounts
2) distributor must be at least OBDI or OBDII b16/b18c
3) reuse your injectors it will make your job easier
4) run either OBDI TB with Map sensor on top or external map (ala 92-3 Civics)
5) linkage must be 90-01 integra or Civic b-series
6) depends on the half-shaft you might require 90-3 axles or 94-01 teg axles, if you have ABS make sure you have ABS rings on the shafts
to say the least simply get a 92+ hydro swap and be done.
Old May 3, 2006 | 05:14 PM
H2on0da3's Avatar
Default Re: 91 B16A -> 97 EX (eg6ajk)
Wow Thanx brother, I researched a completely different motor. Good look.
streetcartuner
10
Jan 6, 2008 08:51 AM
killerpenguin21
May 23, 2007 04:06 PM
VeronasDead
Oct 10, 2006 01:56 PM
DetainedCivic
Apr 17, 2006 10:52 AM
boostin4drcivic
Apr 30, 2004 11:40 AM
