increase ignition timing.
Old Apr 8, 2002 | 08:44 AM
rb26dett's Avatar
Default increase ignition timing.
hi guys how do u increase the ignition timing on a 99 civic ex?
thanks
Old Apr 8, 2002 | 08:53 AM
filetofit
Guest
Posts: n/a
Default Re: increase ignition timing. (rb26dett)
Turn the distributor counterclockwise to advance the timing.
Old Apr 8, 2002 | 09:06 AM
rb26dett's Avatar
Default Re: increase ignition timing. (filetofit)
my friend told me something about loosen 3 bolts from the dist and resetting the ecu but that was for his integra though
Old Apr 8, 2002 | 09:13 AM
filetofit
Guest
Posts: n/a
They should both work the same way. Be sure to tighten the distributor bolts back up when your done and don't advance the timing past about 20 degrees BTDC. Run premium fuel too. Your engine is going to get hotter and you may have trouble passing smog so you might want to turn the timing back for smog.
Old Apr 8, 2002 | 10:12 AM
AzG35's Avatar
You have to jump the service connector above the ECU(green rubber boot). The check engine light will light up. Then you can loosen the 3 distributor bolts, then set the timing. Thats all you need to do, don't forget to remove the jumper.
Old Apr 8, 2002 | 01:22 PM
C-speed's Avatar
Default Re: increase ignition timing. (AzSi22)
Enjoy:
http://www.c-speedracing.com/howto/timing/timing.html
Old Apr 8, 2002 | 03:43 PM
rb26dett's Avatar
Default Re: increase ignition timing. (G3-TEG)
wow thanx for the info guys! but for a light modded car like mine advancing the timing is good or bad?
perry9251
Feb 21, 2018 07:58 PM
ef9robert
Feb 27, 2006 09:08 AM
brusk13
Jan 11, 2006 07:01 PM
johnbrooke86
Aug 23, 2004 04:49 PM
ThisLittleSleepeR
14
Apr 30, 2003 11:16 AM
