installin check valve on 98 civic?
Old Apr 8, 2002 | 07:52 AM
psicrxsi's Avatar
Default installin check valve on 98 civic?
where do you put it? i knoit connects to the map sensor but the map sensor is on the throttle body and there are no vacuum lines for it. so where should the check valve go?
Old Apr 8, 2002 | 08:22 AM
CovertFI's Avatar
Default Re: installin check valve on 98 civic? (psicrxsi)
what kind of check valve setup do you have?
if just the check valve t's and hoses? pull the map off the hook a hose the the sensor. and plug the old location up.
Old Apr 8, 2002 | 10:57 AM
TURBOED-TEG's Avatar
See if a "missing link" is available for your car - do a search on it!!
slowasasnail
Apr 15, 2007 06:36 PM
teggreen4
May 13, 2005 02:12 PM
Johnny_Rocket
Apr 11, 2005 12:35 AM
mracura
May 27, 2002 05:54 AM
