NEW! J&S Ultra SafeGuard now with AFC
Old Apr 8, 2002 | 04:05 AM
John_at_J&S's Avatar
Default NEW! J&S Ultra SafeGuard now with AFC
New J&S Ultra SafeGuard features:
1) Individual cylinder knock retard. Mode switches 1 and 2 control knock retard range and retard all/retard individual operation.
2) Boost retard with both a start **** and a rate ****
3) Optional RPM advance/retard software
4) Built in AFC to modify airflow or MAP signal
5) Built in MAP Limiter. Adjustable from 2.7v to 4.90 v.
6) TPS trick to "pull" signal to 5v at 0 psi. Used to trick ECU out of closed-loop.
7) Mode switches 3 and 4 set the unit to one channel or two channel operation, so it will work on Honda, MR2, Subaru-Eclipse, Miata, RX7.
The AFC part of the unit is not user programmable, so the settings must be pre-programmed. The intent is to provide an airflow voltage/RPM table that will work with a specific injector size and fuel pressure.
If the application is specified at time of order, switches 3, 4, and 5 can be programmed to tweak the AFC, giving eight possible settings.
We have already started shipping units to our Subaru customers, but with lack of data, the AFC is disabled in software. Instead, the Subaru MAP sensor signal passes through the unit, and the adjustable MAP Limiter feature (FCD) is used to prevent fuel cut.
The hardware exists and is working, we just need data for the AFC part of it. If anyone is using an Apexi S-AFC with a MAP sensor, send me your settings and injector size.
If anyone else has ideas for settings, please let me know.
Introductory price is $525.00. Uses factory knock sensor.
[Modified by John at J&S, 11:24 AM 1/8/2003]
Old Apr 8, 2002 | 04:38 AM
SIK IN DA HED's Avatar
New User
Default Re: NEW! J&S Ultra SafeGuard now with AFC (John at J&S)
hmm... something new for those who like to play with other options in tuning...
Old Apr 8, 2002 | 05:05 AM
ZygSpeed's Avatar
Default Re: NEW! J&S Ultra SafeGuard now with AFC (dlplayboy)
Nice!
Getting better and better all the time.
Old Apr 8, 2002 | 11:41 AM
Austin's Avatar
Default Re: NEW! J&S Ultra SafeGuard now with AFC (Zygspeed)
Interesting John...
Old Apr 8, 2002 | 12:36 PM
dbman96's Avatar
New User
3) Optional @ no charge RPM advance/retard software
Tell me more.....
6) TPS trick to "yank" signal to 5v at 0 psi. Used to trick ECU out of closed-loop.
Just a thought, but from my experimenting with this TPS trick, it might be a good idea to put a trim on that "0 psi" point so it can be varied from 5" vacuum to maybe 2-3 psi or you will have a very harsh vacuum-boost transition on some cars.
Old Apr 8, 2002 | 02:56 PM
HidPerf's Avatar
Hey John, how adaptable it the J&S with a non-EFI setup? I sponsor a 640cid Outlaw 10.5 car and I have been trying to get him to run one for a while now. He's running dual Dominators, a multi-Fogger setup and the MSD Digital 7 I believe.
Old Apr 8, 2002 | 03:03 PM
SamC's Avatar
John,
what's your website?
Old Apr 8, 2002 | 05:30 PM
Default Universal unit
Our universal unit will work with an MSD, but you will need MSD PN 8509 magnetic stabilizer to interface to magnetic pickup distributor. Not required if stock ignition triggers MSD White wire.
EFI not necessary. Universal unit is $495.
Old Apr 8, 2002 | 05:36 PM
Default Re: NEW! J&S Ultra SafeGuard now with AFC (SamC)
http://www.safeguard.20m.com
soon to be at http://www.jandssafeguard.com
We need to update the site, since we lowered the prices, and have new models.
yeaitsahonda
Engine Management and Tuning
Feb 21, 2012 03:41 PM
voodoo on 23s
May 18, 2009 07:12 PM
beepy
Dec 28, 2004 08:04 PM
J337_UNIT
Feb 23, 2004 10:38 AM
nickromeo
Feb 10, 2004 08:33 PM
