Torque wrench question...
Old Apr 21, 2006 | 11:04 PM
xxxmikenicexxx's Avatar
Default Torque wrench question...
Hey guys whats up? I know this is a stupid question, but I wanted to ask to make sure. I recently bought a Snap-On click-style torque wrench (QD series) for my engine build/turbo/etc, and I know exactly how to use it but in the book I came across where it says before use to "preload" the tool before every use, and I do not understand this nor know how to do it. Can someone please explain why/how? TIA!!!
Modified by xxxmikenicexxx at 4:03 AM 4/22/2006
Old Apr 22, 2006 | 06:54 PM
Default Re: Torque wrench question... (xxxmikenicexxx)
Anyone?
Old Apr 23, 2006 | 06:45 AM
dlxcupid's Avatar
my best guess is to run the dial all the way up and down? I have the TQ series and I like that setup alot more IMO. Most of the guys at my work have that style of torque wrench and none of them do any sort of preloading before use. We're flat rate techs at Lexus, maybe that's why? haha....anyhow I think you'll be fine, just use it.
Old Apr 23, 2006 | 07:39 AM
Default Re: (dlxcupid)
Thanks for the input! It actually says in the book that the "preloading" involves something like setting the scale at 50% and torquing in both directions...just want to verify with others if this is necessary/a good way to do it? Its just that I am putting together my $5k built block and I need this to be as accurate as possible.
Old Apr 24, 2006 | 09:42 PM
Up
Old Apr 25, 2006 | 12:14 AM
YasRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dlxcupid &raquo;</TD></TR><TR><TD CLASS="quote">We're flat rate techs at Lexus, maybe that's why? </TD></TR></TABLE>
lol
Old Apr 28, 2006 | 08:14 AM
Default Re: (YasRex)
Bump
Old Apr 28, 2006 | 08:43 AM
SkRiBLaH's Avatar
Default Re: (xxxmikenicexxx)
i think what it means is dont just throw it on the bolt and jerk it as fast as you can untill it clicks. i think it wants you to gradualy build up torque until clickage.
Old Apr 28, 2006 | 02:42 PM
EnzoSpeed's Avatar
Default Re: (SkRiBLaH)
This could be unrelated, but this is what I had to do when I bought a new torque wrench.
Set the dial to a medium torque setting so there's a definitive "click" when you turn it. Then put it on a bolt somewhere (use your imagination) and click it several times. It's suppposed to work the internal oil (inside the case) into the moving mechanisms inside. But you're only supposed to do this before the first time you use it.
Old Apr 28, 2006 | 05:36 PM
Default Re: (EnzoSpeed)
That may be what it is, was it a click-type? Snap-on? And you only had to do it for first use?
Old Apr 28, 2006 | 05:48 PM
EnzoSpeed's Avatar
It was a KD Tools click-style. It was only the for the very first use when I pulled it ou of the package (I think?).
Old Apr 28, 2006 | 08:18 PM
postman's Avatar
just use as normal just always remember to unload it after use
Old Apr 28, 2006 | 09:48 PM
Default Re: (postman)
Ok, thanks guys, so the final verdict is use it? Want to make ABSOLUTELY sure because I dont want to risk my very expensive built block
Old Apr 29, 2006 | 12:02 AM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxxmikenicexxx &raquo;</TD></TR><TR><TD CLASS="quote">Ok, thanks guys, so the final verdict is use it? Want to make ABSOLUTELY sure because I dont want to risk my very expensive built block </TD></TR></TABLE>
You'll be fine. Just don't use it on your rod bolts. (Stretch gauge!).
Nataku
Feb 18, 2007 02:04 PM
Junkyard2000
Jan 15, 2006 10:00 PM
2K_TEG
Jul 14, 2002 08:30 PM
ragejed
Jun 30, 2002 02:50 PM
HX_Guy
Jan 12, 2002 10:58 AM
