ELD disabled, still getting ELD code
Old Apr 21, 2006 | 08:02 PM
Gixxerboy02's Avatar
Default ELD disabled, still getting ELD code
I had ELD disable from the beginning when I started tuning. The car was running good for a few weeks until the other day when it went into limp mode. I got no CEL come on but when I go to pull codes I get #20 (Electronic Load Detector)
Why would this code come on when it's disabled in the Uberdata program? And how can I get this to go away?
Thanks
Old Apr 22, 2006 | 07:14 PM
Default Re: ELD disabled, still getting ELD code (Gixxerboy02)
I could realy use some help here guys, my car is just sitting around until I can figure this one out.
When I put a jumper in to check codes the CEL flashes 2 times slow, which should mean code 20?
Old Apr 23, 2006 | 10:49 PM
sleepingEg8's Avatar
you are right about the code being 20 - eld. code 20 will not send you into limp mode... I have been having this same issue.. Try bumping the ecu or putting pressure on the chip while the car is running.. When I do that it goes into limp mode because the chip is loose... i have the eld code to, but it does not trip the CEL.
Old Apr 30, 2006 | 01:16 PM
Default Re: ELD disabled, still getting ELD code (sleepingEg8)
It did end up being a problem with the chip and how it was sitting in the ECU.
I ended up going over the whole car from top to bottom trying to figure out what it was while pulling things apart, and ended up being as easy as playing with the chip.
suprant0010
Apr 19, 2014 02:41 AM
K i l l a B e e.
Oct 15, 2007 11:45 PM
vtechrex
Jul 10, 2006 06:21 PM
esca
Oct 14, 2004 06:34 PM
eg crunkmonster
Jan 14, 2004 03:29 AM
