First time TIG Welding Rate my weld.
Old Apr 21, 2006 | 07:39 PM
Blind-Fashion's Avatar
Default First time TIG Welding Rate my weld.
Please comment and tell me what i should change.
Thanks
Josh
Old Apr 21, 2006 | 08:04 PM
Inspector Gadget's Avatar
Default Re: First time TIG Welding Rate my weld. (Blind Fashion)
Not too bad for a first weld. It took me a while to get ahold of TIG welding. From the looks of the surrounding areas of the weld you didnt prep your material.
Keep it up.
Old Apr 21, 2006 | 08:08 PM
SMSP's Avatar
What's the inside look like?
Old Apr 21, 2006 | 08:10 PM
RaceCarRyne's Avatar
Default Re: First time TIG Welding Rate my weld. (SMSP)
looks like a little too much heat was used in those welds.. im no expert welder either. good work
Old Apr 22, 2006 | 04:34 AM
Default Re: First time TIG Welding Rate my weld. (Inspector Gadget)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Inspector Gadget &raquo;</TD></TR><TR><TD CLASS="quote">Not too bad for a first weld. It took me a while to get ahold of TIG welding. From the looks of the surrounding areas of the weld you didnt prep your material.
Keep it up.</TD></TR></TABLE>
What should I be cleaning with? I'll run out and get whatever today
Old Apr 22, 2006 | 04:56 AM
wade's Avatar
Get a wire brush and use it on SS only. Brush it some, and use some acetone on it, then weld... looks to had a TAD bit too much heat, less heat and you will see alot more color in the weld assuming your CFM is correct and filler rod is not contaminated
Old Apr 22, 2006 | 03:01 PM
I Have an STD's Avatar
wrenchin'
Default Re: First time TIG Welding Rate my weld. (wade)
engloid said it looks good, so it is. looks good random hero!
Old Apr 22, 2006 | 05:39 PM
I use a wire wheel.
Old Apr 22, 2006 | 06:27 PM
jaydmcrx's Avatar
Default Re: First time TIG Welding Rate my weld. (DC2jdmIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2jdmIntegra &raquo;</TD></TR><TR><TD CLASS="quote">looks like a little too much heat was used in those welds.. im no expert welder either. good work </TD></TR></TABLE>
Those welds have great color and the heat affected zone is minimal. Good work man. Especially for the first time.
Make sure you use a stainless brush on that wheel. It will rust if you do not.
Old Apr 23, 2006 | 12:03 AM
Default Re: First time TIG Welding Rate my weld. (jaydmcrx)
dang i suck.. sorry
Old Apr 23, 2006 | 09:52 AM
cua0's Avatar
go the same way all the way around the pipe and you won't end up with such obvious start-stops
otherwise looks pretty good.
Old Apr 23, 2006 | 03:12 PM
mEr's Avatar
mEr
looks very good
wunfstmax
Welding / Fabrication
May 28, 2007 10:10 PM
TIGboy
Dec 16, 2005 09:11 AM
budget
Jun 30, 2005 10:48 PM
Want2race
May 26, 2005 08:01 PM
5STAR3
May 12, 2005 09:18 AM
