rpm too high or a little erratic
Old Apr 21, 2006 | 01:07 PM
jszuba's Avatar
Default rpm too high or a little erratic
I have a question about rpm problems on a 4gen accord (2.2L EXi A/T, 288,000km)
Some time ago the rpm would fluctuate between 1000 and 1500 every second or so, and this was diagnosed as a dirty iacv. The valve was cleaned up and everything was fine for a while. However this is what I get now:
- mostly idle speed is a healthy normal below 1000rpm but sometimes goes up to or over 1000, which means I have to floor the brake at a red to keep at a stop
- rpm while driving seems a tad too high and the car wants to surge forward
- 3rd gear seems minimally reluctant to engage... keeps revving a little too long before switching
- no CELs are thrown
- only mod is a short ram intake
I had a look at other posts, but I have not found a satisfactory solution to this problem... so the question is:
is it a faulty iacv (apparently these things do not fail, I mean this is a very simple mechanism)
or perhaps an EGR?
What to do?
Any help greatly appreciated.
Old Apr 21, 2006 | 05:02 PM
Extremity's Avatar
Default Re: rpm too high or a little erratic (jszuba)
How old is the intake, and, specifically, when was the filter last cleaned? I know that my friends car used to do this, and it turned out the ECU needed more air or something because his filter was horribly dirty and would therefore crank up the RPMs. Then again, I think he also got a CEL.
Old Apr 22, 2006 | 08:53 AM
Ross 2.0's Avatar
In a Junkyard near you.
Check the cone of the filter to be sure the metal plate inside of it is still there. It may have been sucked into the throttle body and resting against the throttle plate.
Heisenberg
13
Feb 5, 2015 10:37 PM
Playbadguitar2
Dec 17, 2012 07:31 PM
bhhong
Mar 2, 2009 12:57 AM
jszuba
May 14, 2006 02:26 PM
fongph
Dec 26, 2004 03:49 PM
