How to adjust cam gears?
Old Apr 21, 2006 | 12:40 PM
crx00's Avatar
Default How to adjust cam gears?
Can someone give me a step by step write up on how to adjust cam gears on a b series motor?
this is my understanding of how to do it. Correct me if i'm wrong.
1. Remove Valve cover
2. Set motor to TDC
3. Loosen appropriate cam gear bolts (intake or exhaust)
4. Turn crank to retard or advance to approriate setting
5. Tighten cam gear bolts
6. Turn crank to make sure everything is ok
7. Put valve cover on
8. Done
Thanks!
Old Apr 21, 2006 | 01:27 PM
mstolars's Avatar
Default Re: How to adjust cam gears? (crx00)
Pretty sure you can skip step 2, I've never done that when adjusting my cam gears. Other than that you have everything right.
Old Apr 21, 2006 | 03:08 PM
Relic1's Avatar
#2 is not needed.
the only step you're forgetting is the part where you strap it to the dyno.
Infinite Auto
Apr 3, 2005 03:59 PM
B18Redline
Dec 2, 2004 07:01 PM
MattD@Stoptech
Apr 9, 2004 07:26 AM
Mr.Integra
Apr 10, 2003 01:39 PM
nerdish
Mar 3, 2002 08:44 PM
