why would you want to get rid of vtec?????????
Old Apr 21, 2006 | 12:28 PM
markysparky's Avatar
Default why would you want to get rid of vtec?????????
http://www.passwordjdm.com/pro...D=380
why would u want to "kill" vtech?????
Old Apr 21, 2006 | 12:29 PM
. a d a m's Avatar
Default Re: why would you want to get rid of vtec????????? (markysparky)
You've got to be ******* kidding me.
Old Apr 21, 2006 | 12:32 PM
Default Re: why would you want to get rid of vtec????????? (Sh!ttyLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS &raquo;</TD></TR><TR><TD CLASS="quote">You've got to be ******* kidding me.</TD></TR></TABLE>
????????? am i just dumb or are these cams made to actually REMOVE vtec???
Old Apr 21, 2006 | 12:33 PM
iBear's Avatar
whoa.
Old Apr 21, 2006 | 12:34 PM
-DesTiNy-'s Avatar
I'm a Jackass
what the ***?
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markysparky &raquo;</TD></TR><TR><TD CLASS="quote">????????? am i just dumb or are these cams made to actually REMOVE vtec???</TD></TR></TABLE>
You're just dumb. "VTEC killer" doesn't mean that it actually stops vtec from engaging.
Syndacate's Avatar
And they're $1,200 too
Werd,I have no idea why this would even be an optin ;-\
Old Apr 21, 2006 | 12:35 PM
Marauder's Avatar
HAhaha....
anyways....true racecars don't need VTEC, the engines are built to work in a certain powerband. Once out on the track the car stays in a certain working RPM range and doesn't need the extra complex valvetrain of VTEC, as the RPM's stay high enough at all times to not need the "base" profile of the cam.
This is used so you can use the advantages of the VTEC engine parts, but do without VTEC and the whole mechanism.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS &raquo;</TD></TR><TR><TD CLASS="quote">You're just dumb. "VTEC killer" doesn't mean that it actually stops vtec from engaging.</TD></TR></TABLE>
are u dumb??? read wat is says.........
"Includes both Intake and Exhaust camshafts, and all components necessary to remove VTEC."
Old Apr 21, 2006 | 12:36 PM
. a d a m's Avatar
Or..maybe it does mean that it removes it?
I don't know, I just thought all you guys were idiots and were misinterpreting it. Damn.
Old Apr 21, 2006 | 12:37 PM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markysparky &raquo;</TD></TR><TR><TD CLASS="quote">are u dumb??? read wat is says.........
"Includes both Intake and Exhaust camshafts, and all components necessary to remove VTEC."</TD></TR></TABLE>
Reading ownz me. Sorry.
-JSpecEk*9-'s Avatar
^^^^^^^^^^^your a dumb expletive!!!!!!!!
Old Apr 21, 2006 | 12:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS &raquo;</TD></TR><TR><TD CLASS="quote">Or..maybe it does mean that it removes it?
I don't know, I just thought all you guys were idiots and were misinterpreting it. Damn.</TD></TR></TABLE>
its ok still love u jpjpjpjp but seriously this was me reaction to reading it:
ladadada ((reading)) ldada..remove vtec?...laldala WTF!? NO VTEC!?#@ VTEC!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
. a d a m's Avatar
Default Re: why would you want to get rid of vtec????????? (JDMEK-9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMEK-9 &raquo;</TD></TR><TR><TD CLASS="quote">^^^^^^^^^^^your a dumb expletive!!!!!!!!</TD></TR></TABLE>
who exactly were you referring to as a dumb expletive?
ineedanEG's Avatar
I'm just as confused as anyone else. Could someone explain the purpose of these cams to me in detail please? Im just really interested
Old Apr 21, 2006 | 12:40 PM
im thinking with all the power u would produce from a turbo....u dont need a vtec, its just another thing to break when producing MAD HONDA POWER y0!
so those ppl with high hp engines dont really NEED vtec......i think......
edit: high hp as in 700hp +
Old Apr 21, 2006 | 12:41 PM
Marauder's Avatar
Default Re: (ineedanEG)
Well, read my post! And read the Toda website...
http://www.todaracing.com/prod....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda &raquo;</TD></TR><TR><TD CLASS="quote">Design
The primary and secondary lobes are designed to be the same size. Overall construction of the cam has been heavily revised. With areas of stress,rigidity and weight all greatly benefiting. Normal cams are created from solid blanks, but the VTEC KILLER CAM is produced from a hollow blank, which not only reduces weight but also improves valve timing accuracy through a reduction in flexing. The cam is designed to bed in quickly and have a low wear rate.
Characteristics
The mid rocker cam is removed & both pins are changed, reducing the valve train mass for better response. Disabling the VTEC system removes fluctuations in the oil pressure system, securing a reliable oil feed to all the main moving components. Lost motion valve should be removed. For max performance, should be used in conjunction with TODA Sports Injection kit.
The kit comes complete with camshafts and special hardware needed to complete the conversion.
Old Apr 21, 2006 | 12:43 PM
ladadada ((reading)) ldada..remove vtec?...laldala WTF!? NO VTEC!?#@ VTEC!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! </TD></TR></TABLE>
to him but wha eva
Old Apr 21, 2006 | 12:46 PM
. a d a m's Avatar
Default Re: (markysparky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markysparky &raquo;</TD></TR><TR><TD CLASS="quote">im thinking with all the power u would produce from a turbo....u dont need a vtec, its just another thing to break when producing MAD HONDA POWER y0!
edit: high hp as in 700hp +</TD></TR></TABLE>
Wrong.
Marauder was right
That would be the only reason that you would possibly want to remove VTEC, thats why I thought all of you guys were idiots when you were saying thats what the function of the cam actually was.
Old Apr 21, 2006 | 01:02 PM
schardbody's Avatar
this is easy. race cars dont need vtec because like said, they are always in the powerband. of coarse a vtec head is designed to flow better stock than a non vtec head, so using a vtec head w/ race cams on a "track car" vtec isnt needed. basically, it has nothing to do w/ simplifiying the valvetrain, its just theres no point in using low cam high cam design of vtec, when the motor is built to always be using the high cam. as long as it idles and gets down the track, no need to worry about low end power w/ is the whole point of vtec anyways.
Old Apr 21, 2006 | 01:03 PM
Soccerking3000's Avatar
Default Re: (Sh!ttyLS)
most of you are retarded lol
Old Apr 21, 2006 | 01:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markysparky &raquo;</TD></TR><TR><TD CLASS="quote">http://www.passwordjdm.com/pro...D=380
why would u want to "kill" vtech????? </TD></TR></TABLE>
and its vtec dumbass
Old Apr 21, 2006 | 01:06 PM
schardbody's Avatar
Default Re: (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">most of you are retarded lol</TD></TR></TABLE>
Old Apr 21, 2006 | 01:07 PM
-Darren-'s Avatar
lol, anyways some one gave you a very good answer up top.
Old Apr 21, 2006 | 01:17 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (-Darren-)
This is the stupidest thread I've read in a long time. So many morons in here, so little time for me to flame before I have to get back to work.
