How many of you broke-in your setups on the dyno?
Old Apr 21, 2006 | 06:29 AM
RTW DC2R's Avatar
Default How many of you broke-in your setups on the dyno?
Any horror stories?
reason I ask is because I dont have much of a choice and didnt have much luck last time around. last time I did this on my all motor setup, I dont think the rings seated properly, I ended up burning a ton of oil, and the motor spun a bearing and shot a rod out the block at just over 20K miles.
with my new boosted setup, Im going to be running NepTune. currently have a P28 with a Crome basemap configured for my setup, so Im hoping it will atleast allow me to start the car and idle it for awhile, and ensure there are no leaks or mechanical issues before trekking to the dyno. I just dont have any way to make changes to the Crome map in case the car DOESNT start with that basemap. this is going to be a completely fresh build.
Old Apr 21, 2006 | 04:24 PM
yee SERIOUS's Avatar
my friend has. i think he dyno'd at like 550 or something
Old Apr 21, 2006 | 04:49 PM
N20civicB18's Avatar
Default Re: (undercoverdc2)
i broke mine in by pulling it out of the garage and smoking the ricer that drove by my house
Old Apr 21, 2006 | 07:05 PM
mrbsponge's Avatar
if you search under my name i started a thread about engine break in. i will be pretty much breakin mine in on the dyno
Old Apr 21, 2006 | 07:18 PM
Black DC2's Avatar
Default Re: (mrbsponge)
broke mine in on dyno
Old Apr 21, 2006 | 09:33 PM
vaporboy12's Avatar
Default Re: (Black DC2)
same
Old Apr 21, 2006 | 11:21 PM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black DC2 &raquo;</TD></TR><TR><TD CLASS="quote">broke mine in on dyno </TD></TR></TABLE>
Old Apr 22, 2006 | 06:06 AM
boostedK20a2's Avatar
how many miles should the break-in period be?
To break in the motor on a dyno... how much should i pay? (ballpark)
Old Apr 22, 2006 | 06:21 AM
mrlegoman's Avatar
Default Re: (boostedK20a2)
I have an AEM EMS, so it was first run and tuned on the dyno. Did some light driving for about 100 miles and then went back for some hard pulls and fine tuning. There were some good post on breaking a car in last year. Check out the archived topics.
Old Apr 22, 2006 | 06:23 AM
Mugencrxsir1's Avatar
Default Re: (mrlegoman)
I will be breaking in my lsvtec on the dyno in June!
That's initial start-up
Modified by Mugencrxsir1 at 11:23 AM 4/24/2006
Old Apr 22, 2006 | 06:56 AM
miamidamian's Avatar
Default Re: (Mugencrxsir1)
i broke mine in my idling 20 minutes changing oil/filter and start doing runs......
part throttle map 1st/////....... then 1 hour later 9k rpm pulls
Old Apr 22, 2006 | 07:33 AM
http://www.mototuneusa.com/break_in_secrets.htm breakin in moto's
Old Apr 22, 2006 | 07:38 AM
gitwidit's Avatar
just make sure it gets some run time before it goes to the dyno. check for leaks and stupid **** that can give you problems and cost $$$ while your working on your **** strapped to the rollers. tuners love that haha
Old Apr 24, 2006 | 09:24 AM
shoebox's Avatar
Default Re: (GITWIDIT)
is breaking it in on the dyno better than breaking it in on the street?
Old Apr 24, 2006 | 10:32 AM
Mr. Vapor's Avatar
Default Re: (vaporboy12)
i built my motor in my garage....took it around the block once, loaded it up on the trailer and tuned it on the dyno with about 5 miles on the motor.
in my opinion, if somehting was going to go wrong, it would have gone wrong in those first 10 seconds when you started your motor.
&lt;---broke his motor in on the dyno!
Old Apr 24, 2006 | 11:09 AM
gitwidit's Avatar
Default Re: (shoebox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shoebox &raquo;</TD></TR><TR><TD CLASS="quote">is breaking it in on the dyno better than breaking it in on the street?</TD></TR></TABLE>
let's put it this way....not a good idea to break in a motor on a basemap.
Old Apr 24, 2006 | 11:14 AM
B18C Turbo's Avatar
really? i was thinking about breaking in my engine on a uberdata basemap? This is not a good idea? Should I just break it in using stock ecu/injectors?
Old Apr 24, 2006 | 12:28 PM
RTW DC2R's Avatar
only thing Im worried about is if my basemap will be able to start my car or not. if it starts, great, if its driveable, wonderful. if not, hopefully I can atleast let it idle. I want to atleast be able to start the car and check for leaks, etc, and *hopefully* allow it to get up to operating temp. that way I can set base timing, check timing belt tension, etc etc. Id hate to bring it to the tuner and have him start it, and find all these problems before even getting on the dyno.
Old Apr 24, 2006 | 03:51 PM
white95eg's Avatar
Default Re: (B18C Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C Turbo &raquo;</TD></TR><TR><TD CLASS="quote">really? i was thinking about breaking in my engine on a uberdata basemap? This is not a good idea? Should I just break it in using stock ecu/injectors?</TD></TR></TABLE>
I was thinking the same thing... Now I don't know what to do. Please explain.
Old Apr 24, 2006 | 04:26 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT &raquo;</TD></TR><TR><TD CLASS="quote">
let's put it this way....not a good idea to break in a motor on a basemap.</TD></TR></TABLE>
I would rather break it in on a street tune then a dyno tune. Simulate the exact loading conditions, wideband in the car, tuner in the passenger seat, etc. Cheaper then dyno time as well. If this option is available, this is the way I do it.
Old Apr 24, 2006 | 05:42 PM
shoebox's Avatar
Default Re: (Blown90hatcH)
I wasn't thinking about breaking it in turboed...I just meant breaking it in all motor with stock injectors and everything
Old Apr 25, 2006 | 03:52 AM
gitwidit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C Turbo &raquo;</TD></TR><TR><TD CLASS="quote">Should I just break it in using stock ecu/injectors?</TD></TR></TABLE>
If you don't have the option to start tuning right after startup then stock ecu and injectors are the next best thing
sowellman88011
15
Mar 24, 2015 06:23 PM
Boostinb20!
Jun 4, 2009 08:15 AM
hbyrd8701
May 18, 2008 09:40 PM
NoBottleJustThrottle
25
Jul 19, 2006 05:15 PM
crx1856
Oct 16, 2003 10:23 PM
