Suspension & Brakes Theory, alignment, spring rates....
NRG engine damper.. installed correctly?
Old Apr 21, 2006 | 12:48 AM
Outkast95LS's Avatar
Default NRG engine damper.. installed correctly?
Just picked up an NRG engine damper. However, it isnt made for the DC application, so they provided me with the hybrid parts. I couldnt figure out a way to mount it, so i just improvised with what i got. This is how i mounted it... havent driven it yet so i dunno if there are any improvements or not. What do u guys think? Is the way i mounted it flawed?
Old Apr 21, 2006 | 02:14 AM
idrive's Avatar
Default Re: NRG engine damper.. installed correctly? (Outkast95LS)
I dont have a DC...
but heres what i think...
the way you have it mounted to your block looks ok?
if its mounted to your block - if its just mounted to your motormount it might not be that effective.
but dude - you should for sure rethink the other mount - its gonna rock your strut bar to pieces...
i would either drill into the shock tower and mount it or try and figure out a way to mount it to one of your strut tower bolts...
something stronger...
gluck
Old Apr 21, 2006 | 09:19 AM
Joon Joon's Avatar
Default Re: NRG engine damper.. installed correctly? (idrive)
try and mount it to the bolt that holds the upper a arm.. looks like it should go there
Old Apr 21, 2006 | 11:10 AM
Default Re: NRG engine damper.. installed correctly? (Joon Joon)
Thats where i wanted to mount it too.. the upper a arm bold. But the bracket woudnt work there and i eventually just used the strut bar mounting.
Old Apr 21, 2006 | 11:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idrive &raquo;</TD></TR><TR><TD CLASS="quote">I dont have a DC...
gluck</TD></TR></TABLE>
IT's mounted to the motor mount. Not sure if anything can be done to make it mount to the block. Thats the way the mount came. I cant even use both the mounting points, i couldnt only use one.
Old Apr 21, 2006 | 11:17 AM
94eg!'s Avatar
#1 Super Guy
Loved
Can anybody explain what this thread has to do with suspension? I thought that was what we are supposed to talk about in here...
Can we get a lock please?
Old Apr 21, 2006 | 11:38 AM
Jayboy's Avatar
Default Re: NRG engine damper.. installed correctly? (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Can anybody explain what this thread has to do with suspension? I thought that was what we are supposed to talk about in here...
Can we get a lock please?</TD></TR></TABLE>
umm so no talk about traction bars, sway bars, cages, motor mounts or for that matter anything to do with chassis rigidity??? L2P noob
Old Apr 21, 2006 | 11:58 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: NRG engine damper.. installed correctly? (Jayboy)
I was not aware that sway-bars, and traction bars were NOT suspension components. I sure learned somthing today (NOT). You still didn't explain what this has to do with suspension...
And I don't think I've ever read a thread in here about motor mounts, roll cages or chassis rigidity (unless somone askes that age old question, "which STB works best")...
LAME...
Old Apr 21, 2006 | 12:39 PM
What other forum would suit fit for engine dampers, motor mount inserts ,etc?
Old Apr 21, 2006 | 12:46 PM
94eg!'s Avatar
#1 Super Guy
Loved
Personally, I would post it in the tech forum for your particular chassis (but that's just me I guess)...
Old Apr 22, 2006 | 10:01 AM
Relic1's Avatar
the way it's mounted I figure it will take about a week before the mounts brake off.
http://img.photobucket.com/alb...m.jpg
bottom right, the second engine mount location is not being used. Both bolts on the motor mount should be used to keep the mount from twisting.
To me that engine mount looks like a SOHC mount, I would have expected the DOHC mounts to look more like this... http://www.sportcompactonly.co...l.jpg
Old Apr 22, 2006 | 12:20 PM
chrisw85's Avatar
same if not better would be achieved with motor mount inserts or full poly jimfab mounts.
Old Apr 22, 2006 | 12:29 PM
ProjectDarkBlack's Avatar
Default Re: (chrisw85)
I don't think someone with almost 2900 posts could be called a noob, especially be someone with 1/10th that. Drivetrain is different than suspension, that would be like posting an axle question but close enough. Honestly who gives a ****...
Old Apr 22, 2006 | 01:39 PM
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">the way it's mounted I figure it will take about a week before the mounts brake off.
To me that engine mount looks like a SOHC mount, I would have expected the DOHC mounts to look more like this... http://www.sportcompactonly.co...l.jpg</TD></TR></TABLE>
i felt the same way. i thought the mount they gave me did look kind've awkward. I guess i'll have to ask NRG to send me another mount.
Old Apr 25, 2006 | 09:22 PM
Jayboy's Avatar
Default Re: (ProjectDarkBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">I don't think someone with almost 2900 posts could be called a noob, especially be someone with 1/10th that. Drivetrain is different than suspension, that would be like posting an axle question but close enough. Honestly who gives a ****...</TD></TR></TABLE>
So what you're saying is, I can be a total post ***** and get my total count up to 5bazillion and be the ultimate guru/know-it-all right? Cool ill work on that, thanks dude
Modified by Jayboy at 11:25 PM 4/25/2006
Old Apr 26, 2006 | 12:37 AM
Default Re: (Jayboy)
Old Apr 26, 2006 | 07:45 AM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayboy &raquo;</TD></TR><TR><TD CLASS="quote">So what you're saying is, I can be a total post ***** and get my total count up to 5bazillion and be the ultimate guru/know-it-all right? Cool ill work on that, thanks dude
Modified by Jayboy at 11:25 PM 4/25/2006</TD></TR></TABLE>
It would probably be more benificial to you if you just worked on being less of a jiant douche...
Old Apr 26, 2006 | 09:32 PM
Jayboy's Avatar
It would probably be more benificial to you if you just worked on being less of a jiant douche...</TD></TR></TABLE>
kkthxbye
Old Apr 26, 2006 | 09:41 PM
..hey thanks guys for contributing to my thread with your little school girl arguments.
Old Apr 27, 2006 | 04:39 PM
optikal_blitz's Avatar
i agree with Relic1
think about what it would be like if you did not have that strut bar, ya know?
after a quick search this is how i found it set up with a b18
i think that might give you a better idea of how its supposed to be setup.
(to others bickering about postcount and what belongs where, think before you type: is this gonna help the OP? as a matter of fact, the damper with help with power transfer and decrease wheelhop- which is directly related to the handling characteristics of a car in the holeshot)
Old Apr 27, 2006 | 06:58 PM
Default Re: (optikal_blitz)
Thanks for the pic. I know where it should be mounted, looks like i gotta modify the mount that goes on the upper LCA bolt. But the mount that goes on the actual mount is different though.
Old Apr 27, 2006 | 07:15 PM
chrisw85's Avatar
the damper will help, but poly mount inserts or even windoweld/marine poly filled lower torque mounts/rear lower mount would have achieved the same if not better and more effective. either method would help to a certain extent short of solid metal mounts.
VougeEJ6
10
Jun 25, 2010 08:41 AM
instunnoodoh
Mar 5, 2008 10:41 AM
jdmjeff
Nov 30, 2005 12:51 PM
desert eagle
May 12, 2004 02:49 PM
DC2_Jspec
Jul 22, 2002 10:20 AM
