b16a questions. injector and how to get more HP?
ok... so katrina hit here.. so not to many jobs now.... so i dont have a job and i have a b16 civic hatch... very clean.... i have 3inch intake, full JUN headers, catback, exhaust system
my friend has a DSM and he has ssome 650 injectors.... any way i could put them on my car and how? i also have a revhard turbo manifold and a turbo,wastegate, charge pipe.. i am going to turbo it soon... just wanted to know how i could put them injectors ona nd would it be good if i did and would it be ok if i am not turboed yet?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaeg6 »</TD></TR><TR><TD CLASS="quote">not a good idea. its too much. even with turbo. not unless if its a full race turbo</TD></TR></TABLE>
That's a stupid statement, it's not about what kind of turbo or anything like that, it's about how much power you are producing.
That being said, they are too big, and are probably even too big when you go boost. It really depends on what you are planning to do. In any case, you cannot drive around with them all motor.
put some 550cc injectors.....put a hondata on it....put a lower compression headgasket and boost 14-20 psi....and you should be good for awhile....that what my cousin has along with arias piston(moly coated)manley rods...stock head...arp head bolts and rod bolts sk2 manifold and he is pushing 385 with a autronic(<---spelling???). on 20 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tempsohc »</TD></TR><TR><TD CLASS="quote">put some 550cc injectors.....put a hondata on it....put a lower compression headgasket and boost 14-20 psi....and you should be good for awhile....that what my cousin has along with arias piston(moly coated)manley rods...stock head...arp head bolts and rod bolts sk2 manifold and he is pushing 385 with a autronic(<---spelling???). on 20 psi</TD></TR></TABLE>
Just because that worked for your cousin, doesn't mean it will work for the OP. They could have different hp goals, and also could have completely different turbo setups.
If you want to know what size injectors you will need, check this out:
http://www.z31.com/software/injector.pl
