removing seats
Old Apr 20, 2006 | 08:26 PM
chunkybs's Avatar
Default removing seats
i tred searching but did not get any results, so my questions is how do i remove the seats? wear are the bolts, what size sockets are needed, how hard is it to remove them and re-install them. i'm looking to take out the pass. seat and back seat from my '94 Si hatch.
any tips would be great, thanks guys
Old Apr 20, 2006 | 08:31 PM
EL Vap133's Avatar
Default Re: removing seats (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">if you dont know how to remove a seat in a honda, you need to stay from cars...four ******* bolts on the bottom and take the sucker out....</TD></TR></TABLE>
LOL.
4 bolts, I believe you need a 12mm socket. To get to the front ones it is no challenge whatsoever. For the rears, take the plastic panels off to get to the bolts.
Old Apr 20, 2006 | 08:32 PM
chunkybs's Avatar
is the back seat all 1 piece or is it a top and bottom? so i just have to find the 4 bolts along the bottom (i would assume there under the seat cushion) and remove them then it all comes out?
Old Apr 20, 2006 | 08:36 PM
chunkybs's Avatar
Default Re: removing seats (EL Vap133)
wear are the panels? under the cushion? on the floor board?
i havn't taken a look yet cuz i just found out like 30min ago that a kid wants to run me at the track this weekend and i'm gunna need to lightin up as much as possible.
'94 Si with mods listed below Vs. newer body style automatic tiburon with borla exhaust. he thinks i'll win and i think he will but i guess we'll see. what do you guys think my chances are?
ZipTieGUy's Avatar
are you ******* serioues
the front seats has 4 bolts. the rear you lower it down and look at the outside of each seat theres a small plastic plug you use pliers and pull them out, that will give you room to push each top peice towards the side then pull it off. after that the botoom peice has 1 bolt remove that then left and pull and wiggle
Old Apr 20, 2006 | 08:45 PM
E46Kid's Avatar
Lol, yeah its the 12mm use a socket wrench two in the front, below the seats and two in the rear, probably about 2-3 mins max to remove!
Old Apr 21, 2006 | 12:00 PM
chunkybs's Avatar
i got the front seat out no problem like you said, back seat bottom cushon came out no prob, but i don't see how you take out the backs of the back seat, it seens to be glued or welded down in the center and is somehow hooked to the sides of the car. how do i go about removing it.
also, if i do take that back piece out, will it be able to go back in or once it's out is it out for good?
Old Apr 21, 2006 | 02:31 PM
chunkybs's Avatar
bump
Old Apr 21, 2006 | 02:35 PM
Chong's Avatar
ballin
Default Re: (chunkybs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunkybs &raquo;</TD></TR><TR><TD CLASS="quote">i got the front seat out no problem like you said, back seat bottom cushon came out no prob, but i don't see how you take out the backs of the back seat, it seens to be glued or welded down in the center and is somehow hooked to the sides of the car. how do i go about removing it.
also, if i do take that back piece out, will it be able to go back in or once it's out is it out for good?</TD></TR></TABLE>
There's a little clips between each back piece, and the rear quater panel. Get the clip out, and shove the back away from the middle, then take it out..
Old Apr 21, 2006 | 09:06 PM
chunkybs's Avatar
ok, so the clip is holding the seat to the quartel panel, but how is that center piece held on, it seemed to be on there pretty good
Old Apr 21, 2006 | 09:09 PM
Chong's Avatar
ballin
It's kind of "hooked" in, you have to kind of shove each back piece away from the center part to get it "unhooked". It really isn't rocket science.
Old Apr 21, 2006 | 09:32 PM
termi's Avatar
not to be rude, but there is a big picture DIY in the sticky. check it out, im sure it will help
Old Apr 21, 2006 | 10:18 PM
chunkybs's Avatar
Default Re: (termi)
ohh ****, thanks that helps a lot. i see now that the metal piece in the center stays there, i was thinking it unhooked from the floor
Old Apr 22, 2006 | 01:42 PM
chunkybs's Avatar
that helped a ton, took like 3min. now i need to remove the sound deadening and paint it, what are you thoughts on cleaning it up nice and spraying it with arousal truck bed liner stuff. is it ok to spray the fuel pump cover thing?
Old Apr 22, 2006 | 01:46 PM
Walterronny's Avatar
do you not have service manual? if you want i put the steps from manual for you.
Old Apr 22, 2006 | 01:53 PM
chunkybs's Avatar
Default Re: (Walterronny)
steps on painting the floor?
no i don't have one
Old Apr 22, 2006 | 01:57 PM
steps for to take off the front seats
Old Apr 22, 2006 | 02:29 PM
chunkybs's Avatar
i got all the seats out, i just want to remove the sound deadening and paint it now
Old Apr 22, 2006 | 02:53 PM
op, sorry man, i havent the steps for to remove it.
Old Apr 23, 2006 | 10:47 AM
Chong's Avatar
ballin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunkybs &raquo;</TD></TR><TR><TD CLASS="quote">i got all the seats out, i just want to remove the sound deadening and paint it now</TD></TR></TABLE>
Dude, instead of asking the questions in this thread, just search. Click that red link in the top right corner and search. Make sure you click "Archived Cntent" to get older thread.
Old Apr 23, 2006 | 11:59 AM
chunkybs's Avatar
i did search but it turned up nothing. i'll try the archived thing next time
Old Apr 23, 2006 | 01:07 PM
Soccerking3000's Avatar
you are doing all of this so you can race an automatic tiburon? :shakeshead:
Old Apr 23, 2006 | 01:36 PM
chunkybs's Avatar
Default Re: (Soccerking3000)
actually we never raced, i didn't want to drop $20 for 1 race and i don't race on the streets
Old Apr 23, 2006 | 01:54 PM
Default Re: removing seats (chunkybs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunkybs &raquo;</TD></TR><TR><TD CLASS="quote">wear are the panels? under the cushion? on the floor board?
'94 Si with mods listed below Vs. newer body style automatic tiburon with borla exhaust. he thinks i'll win and i think he will but i guess we'll see. what do you guys think my chances are? </TD></TR></TABLE>
you never were gunna race anyone were you, just to lazy to search for the 4 or 5 stickied threads on how to remove the interior
Old Apr 23, 2006 | 01:56 PM
92hndciv's Avatar
Dude its SOOOO easy theres 4 bolts and u just take em out and pull the seat out..took me 10 miniutes to do both and i took a break inbetween
SomeDude56
Nov 13, 2005 10:01 PM
kaj
Jul 25, 2003 12:44 PM
markpaco
Oct 12, 2002 04:16 PM
gleinz
Sep 25, 2002 12:33 PM
rasta420
Aug 22, 2002 12:54 PM
