96-98 EK civic square Fog light install... HELP.
Old Apr 20, 2006 | 08:09 PM
blazed_racer's Avatar
Default 96-98 EK civic square Fog light install... HELP.
hey, im having trouble figuring out how to install these fog lights onto a 96 bumper.
i know how to wire it up, just cant seem to figure out how to fit it up, i dont want to start cutting it, as i have searched other old topics, and they say you dont cut, etc? but doesnt tell me much more,
there has been alot of guys who have fitted these, so go on throw me some help
as far as i know, all the OEM brackets etc are complete with the foglight unit itself. just need some instructions on fitting to bumper. were to start etc.
Old Apr 20, 2006 | 09:09 PM
Default Re: 96-98 EK civic square Fog light install... HELP. (blazed_racer)
anyone...
Old Apr 20, 2006 | 10:24 PM
BlueIntegraBoy's Avatar
http://www.hondaautomotivepart....html
Old Apr 21, 2006 | 01:13 AM
hey thanks!!
the pic shows a circle light, will the cut out instructions be the same for the square fog?
Old Apr 21, 2006 | 01:19 AM
Default Re: (blazed_racer)
Should be the same
Old Apr 21, 2006 | 04:26 AM
sorted... that link above helped alot, just follow the instructions on how and where to cut the grill.
basically the square light brackets bolts up to the pre-mould holes, and then you bolt the light unit to the bracket,
then wire them up.
Old Apr 21, 2006 | 06:15 AM
EJ8kid's Avatar
the ground wire is too small...you might run another ground b/c the orignal ground will burn up...happened to mine 3 weeks after i got them. just my 2 cents...
Old Apr 21, 2006 | 06:24 AM
jdmztrane's Avatar
Default Re: (EJ8kid)
I never had a problem with the ground. I just ran it to the ground where the valve cover ground is.
The circle foglights have the same cut out so it will work perfectly.... Square ones look better IMO
Old Apr 24, 2006 | 06:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8kid &raquo;</TD></TR><TR><TD CLASS="quote">the ground wire is too small...you might run another ground b/c the orignal ground will burn up...happened to mine 3 weeks after i got them. just my 2 cents...</TD></TR></TABLE>
oh yeap. cheers for that,
Old May 24, 2006 | 09:39 PM
chsamia's Avatar
wow book marked
96 EJ8
12
May 13, 2013 12:32 PM
zenon8890
Jan 29, 2008 07:38 AM
grilledcheese33
10
Nov 3, 2007 08:04 PM
DeDonDeRosa
Feb 24, 2007 07:22 AM
EM1VtecSi
Welding / Fabrication
Feb 25, 2005 07:20 AM
