obd 2 to obd1
Old Apr 7, 2002 | 08:58 PM
cr00klyn718's Avatar
Default obd 2 to obd1
my boy got a b16a2 off a 00'si on his hatch and we want to change it from obd2 to obd1?want what are the benifits of this?
thanks
Old Apr 8, 2002 | 02:56 AM
kenji's Avatar
25 Year Member
Default Re: obd 2 to obd1 (cr00klyn718)
Here are some benefits:
-No CEL associated with running a test pipe
-Easy and cheap to 'rechip' and run a better program
-Many choices for different programs to run
-No gay codes associated with running too rich/lean
-No gay cylinder misfire codes
-kenji
Old Apr 8, 2002 | 05:28 AM
Default Re: obd 2 to obd1 (kenji)
thank...but ne one know how we can change it from obd2 to obd1??
Old Apr 8, 2002 | 05:46 AM
kenji's Avatar
25 Year Member
I can make you an OBD2 to OBD1 ECU conversion harness. It is plug and play. Dozens of other Honda-Tech members are using my harnesses. Email me for more info.
-kenji
Old Apr 8, 2002 | 07:57 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I helped drop a 96 B18C1 engine into a 94 GS-R (already had OBD-1 harness and ECU). All we had to do was use the 94 distributor and swap the injector plugs on the 94 wiring harness.
thanks..what else is needed though?
420waipio
27
May 31, 2011 03:48 PM
Jabinya
Jul 16, 2007 04:33 PM
NsX_CrX
Nov 19, 2005 12:49 PM
blackedoutcivic
Jan 29, 2003 08:17 PM
shawnc21
Jan 9, 2003 11:21 AM
