suspension clicking..dont know where is from
alrite...it clicks when there is a bump, and also when im turning. its not the axles. when the car is parked and you make the front bounce hard, it clicks. its comming from the driver side. check all the strut bolts. there all snugg and the brake bolts too. dont know where this is comming from.
no the axles are brand new...less than 10k.. just did a swap. i was going to buy the poly-urethane bushing kit was told it wasnt worth it.
back to the problem...it wasnt suddle. it was progressive. first it was small and only click once in a long drive. and it built up. will check bushings this weeken. i've been stumped for a while now.
mine does this too
on a turn or a bump it click on the front right passenger side
then when i slow down fast i hear a click in the back then i let of the brake then hit it again and it clicks
check the strut that's clicking for a slight seep as well. I had a car slooowly drain off some of its shock fluid (just worn - it happens) and replacing the strut fixed the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doodooheadfart »</TD></TR><TR><TD CLASS="quote">mine does this too
then when i slow down fast i hear a click in the back then i let of the brake then hit it again and it clicks</TD></TR></TABLE>
thats exacly what it does...except my is in front. and my back brakes does the same thing....hahaha
EeF
13
May 31, 2010 12:36 PM
Turbo E
Sep 3, 2005 07:45 AM
SickWitIt2.0
Mar 7, 2005 02:27 AM
broken tie rod end couldn't have been that pricey, either.
