Distributor Question-Searched and Actually Worth Reading
Old Apr 20, 2006 | 04:38 PM
hondakevin21's Avatar
Default Distributor Question-Searched and Actually Worth Reading
I hope this isn't a retarded question. I have a 1997 Civic Ex, I swapped in a 1992 B16 everythings been done correctly (this isn't my first nor last swap). Now that i'm close to being done i'm unsure as how to wire the distributor, i'm using my oringinal engine harness. Over the years i've had friends who have taken care of this, but now they aren't around I realized I don't know how they wired the OBD1 distributor to work with the OBD2 Engine harness. I'm using the P30 ecu along with a conversion harness, and everything ready to roll except this. Thanks, Kevin.
Old Apr 20, 2006 | 07:17 PM
Default Re: Distributor Question-Searched and Actually Worth Reading (hondakevin21)
Come on people I just need to know how the hell to wire this to make it work.
Old Apr 20, 2006 | 10:19 PM
Takumi Fujiwara's Avatar
I haven't done this myself because I haven't needed to. But can't you just match up the colors of the wires - engine harness side to distributor side? From OBDII to OBDI, it's only a couple wires that are in different pin positions.
Old Apr 21, 2006 | 11:32 PM
Default Re: Distributor Question-Searched and Actually Worth Reading (Takumi Fujiwara)
I'm not sure that is what i'm trying to figure out.
ondenoantra
10
Oct 29, 2025 06:37 PM
4dek
Jul 6, 2008 06:13 PM
hondakevin21
Apr 20, 2006 07:33 PM
Neukin
Feb 22, 2003 10:39 AM
