Engine compression was not bad but hydrolocked??
Old Apr 20, 2006 | 03:39 PM
airsodam's Avatar
Default Engine compression was not bad but hydrolocked??
Hi
I have a 94 integra rs
. i did compression test today.
The result was a little less than 185 (182~183) for all three except 2nd one from the timing belt. the second one was 173 (172~175)....
MY question is that "Did the happening make the second copression slightly lower than others?
A week ago" on rainy day i had a hydrolocked..yes, i have AEM CAI
I totally had no idea what was going on at the time, now accidently reserched about the hydrolock.
Here was what it feels like, i was going for 30~35mph, all of sudden whole car was vibrating(like i were going over "tiny bumps" that are to wake you up which can be seen on the side of the highway; the rest area)
I thought at first my clutch was sliping, so i put it in the nuetral.....and the car became normal.....vibrating for about 4seconds.
about 15seconds later in my parking lot....it started again...and i put the gear in nuetral, nothing happended!!!!
Right away, i stopped the engine..
10mins later, i started again and works just fine, and i dont notice anything so far..
It is long, sorry guys.
Forgot to say!
I dont thinnk "i ran over a puddle"...i avoided water spots as much as possible b/c my paint chipping off( to slow down the process)
but it was raining a little heavy tough...southern CA..
Modified by airsodam at 4:52 PM 4/20/2006
Modified by airsodam at 5:19 PM 4/20/2006
Old Apr 20, 2006 | 05:27 PM
Sam92Teg's Avatar
Default Re: Engine compression was not bad but hydrolocked?? (airsodam)
You probably sucked in some water, but not enough to hydro-lock or cause any damage. If your engine doesn't knock, you should be ok.
Old Apr 20, 2006 | 07:32 PM
98IntegraLSNonVtec's Avatar
Default Re: Engine compression was not bad but hydrolocked?? (Sam92Teg)
yeah, you would know if you hydrolocked...luckily it doesn't sound like you did!
Old Apr 20, 2006 | 11:38 PM
airsodam's Avatar
Default Re: Engine compression was not bad but hydrolocked?? (98IntegraLSNonVtec)
Yea~? that sounds good!
Is there anything i should pay atention to ??
please help me out.
Old Apr 20, 2006 | 11:45 PM
b20integrapower's Avatar
you should be good if you didnt actually lock up the motor..and by the looks of it..you didnt...you got lucky..move forward..id just suggest changin the oil...but besides that ur good to go...and yes...oc weather sucked a couple weeks back...now its really nice here..
Old Apr 21, 2006 | 01:30 AM
Haleiwa-Brando's Avatar
Default Re: Engine compression was not bad but hydrolocked?? (b20integrapower)
If your engine has high miles, then your compression test is fine. Did you perform the test correctly?
Also, try putting a few tee spoons of oil down in the cylinder that is under question, perform the compression test again, and if you see better numbers you have a problem.
Old Apr 21, 2006 | 10:03 PM
airsodam's Avatar
Default Re: Engine compression was not bad but hydrolocked?? (Haleiwa-Brando)
Um... i think a did it right...fully warmed it, full throtle, all plugs out,..
My mileage is almost 170000, just few hundres mile away from it.
I guess it will go up if i put little bit of oil inside..
Kicker2900
May 29, 2019 12:41 AM
baggedd50
43
Jun 20, 2012 09:37 AM
aimbot
Apr 24, 2007 12:16 PM
CivicEX_Kidd
Sep 24, 2005 11:23 AM
wutangben
Jun 2, 2003 06:21 PM
