Axels ??
Old Apr 20, 2006 | 02:40 PM
BsmoothR's Avatar
Default Axles ??
I am bringing a 97 R back from the dead(yard). Having troubles finding axles that work. The drivetrain I have is a bseries with a type r trans and set up for a 5 lug in a 92 hatch. It seems that the axles I have are to short. Ordered 98 gsr axles,nope same ones I already have. Are type r axles longer?? Is the half shaft different? Any advice is welcome. Thanks Matt
Modified by BsmoothR at 4:31 AM 4/21/2006
Old Apr 20, 2006 | 02:44 PM
RTW DC2R's Avatar
"bringing a 97 R back from the dead" is not the same as swapping an R motor into a hatch. youll have better luck in the Hybrid forum, or the search feature.
Old Apr 20, 2006 | 02:49 PM
BsmoothR's Avatar
Default Re: (clip the apex)
Clearly you can't read, I am swaping my R HATCH parts into a integra type R.
Old Apr 20, 2006 | 02:55 PM
RTW DC2R's Avatar
maybe your sentence structure needs some tuning. regardless, you will have better luck in the Hybrid forum. or go to autozone and get some reman bseries axles.
Old Apr 20, 2006 | 03:08 PM
cltitus's Avatar
hasports
Old Apr 20, 2006 | 05:34 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: (cltitus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">hasports</TD></TR></TABLE>
That's a good bet since they have had to develop a number of different axle designs that handle angle differences that might cause universal joint wear because motors have been swapped back and forth.
Another good possibility is http://www.raxles.com &lt;--Marty the owner frequently answers the phone himself, and he's learned a lot the hard way. He could probably tell you right away what's wrong and what axles you need, and he probably has a couple of different strength versions in stock.
Old Apr 20, 2006 | 05:40 PM
BlueR's Avatar
Default Re: (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Another good possibility is http://www.raxles.com &lt;--Marty the owner frequently answers the phone himself, and he's learned a lot the hard way. He could probably tell you right away what's wrong and what axles you need, and he probably has a couple of different strength versions in stock.</TD></TR></TABLE>
marty
Old Apr 20, 2006 | 06:19 PM
slackeR1366's Avatar
Default Re: (BlueR)
I'm giving Marty a call tomorrow. Have heard nothing but good things from Raxles.
Old Apr 20, 2006 | 07:21 PM
BsmoothR's Avatar
Default Re: (R1366)
Will call Friday morning.
90AccordVTEC
Feb 23, 2007 08:53 AM
BsmoothR
Apr 20, 2006 08:00 PM
aznboysrfr
10
May 2, 2004 07:37 PM
turkdog
Nov 27, 2003 04:05 PM
