Found A Surprise. Need some Input!!!!
Old Apr 20, 2006 | 02:04 PM
rex_racer728's Avatar
Default Found A Surprise. Need some Input!!!!
So my 94 integra has been sitting all winter and collecting dust. Ive done some small things to it such as new timing belt, alt belt and waterpump, and new brakes. Well its in paint right know and I purchased a JDM valve cover as a spare. So i got to the shop to change valve covers and I see brown milky oil. Only on top of the oil caps and on the underside of the valve cover!! Its not chunky or thick its just milky brown. The dipstick looks like regular oil nice and golden. Now my question is do you think that it is just moisture of a blown headgasket. I searched and from other posts it seems to be just moisture but right know Id rather get some opinons. Thanks
Old Apr 20, 2006 | 02:32 PM
JDMtype Eg6's Avatar
How are your coolant levels? Also what are your climare levels. becase it could just be from moisture in the oil because of cold weather.
Old Apr 20, 2006 | 02:36 PM
chucky.s's Avatar
as stated above by JDMtype Eg6 . more than likely just moisture.^^^^
Old Apr 20, 2006 | 02:59 PM
Default Re: (chucky.s)
Yeah well in the winter when it was sitting it was between 0-35 degrees. Im up in here in northern idaho. It was started about once a month but has been moved everyday for the last 2 weeks just to get it in and out of the shop!! What should i do to check and make sure that it is just moisture.
Old Apr 20, 2006 | 04:49 PM
LSEGHATCH's Avatar
Default Re: Found A Surprise. Need some Input!!!! (rex_racer728)
leakdown and compression test wouldn't hurt, might help
Old Apr 20, 2006 | 05:07 PM
boostedblkef's Avatar
Default Re: Found A Surprise. Need some Input!!!! (LSEGHATCH)
flush everything and check again prob just moisture
jtz54
Aug 23, 2016 12:25 AM
4serioferio
Sep 15, 2010 04:14 PM
GibsonNO!
Oct 22, 2008 06:19 AM
shortlid
32
Jan 2, 2007 11:15 AM
Dustinf
Nov 16, 2006 03:04 PM
