portflow valvetrain and JUN 3 cams, will this work.
Old Apr 20, 2006 | 12:24 PM
ALLBOSSBRA's Avatar
Default portflow valvetrain and JUN 3 cams, will this work.
Has anyone run this combo? Dont want to blow up my cherry b20 vtec bro.
Thanks.
Old Apr 20, 2006 | 12:45 PM
4piston's Avatar
Default Re: portflow valvetrain and JUN 3 cams, will this work. (ALLBOSSBRA)
I had portflow springs with Skunk Stage 2s and they lost more than 5-7 lbs spring pressure after 13 passes down the 1/4. I wouldn't use them in my motor with that cam.
Not to say that they aren't quality stuff...its OEM Honda stuff, but that is a lot of cam for that little spring.
Old Apr 20, 2006 | 01:08 PM
ninesecrx's Avatar
Default Re: portflow valvetrain and JUN 3 cams, will this work. (4piston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4piston &raquo;</TD></TR><TR><TD CLASS="quote">I had portflow springs with Skunk Stage 2s and they lost more than 5-7 lbs spring pressure after 13 passes down the 1/4. I wouldn't use them in my motor with that cam.
Not to say that they aren't quality stuff...its OEM Honda stuff, but that is a lot of cam for that little spring.</TD></TR></TABLE>
Not all of Portflow springs are OEM, they sell type r stuff but also have a much stronger spring as well.
Old Apr 20, 2006 | 01:17 PM
4piston's Avatar
Default Re: portflow valvetrain and JUN 3 cams, will this work. (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">
Not all of Portflow springs are OEM, they sell type r stuff but also have a much stronger spring as well.</TD></TR></TABLE>
Thanks for clearing that up I guess I should have said that I had the OEM R outers with Portflow inners.
pchan
Jan 4, 2007 09:57 PM
Amped
Aug 30, 2006 04:33 PM
staticchmbr
Apr 26, 2004 08:16 AM
Butch
Mar 28, 2003 09:00 PM
