Suspension & Brakes Theory, alignment, spring rates....
drums to discs!
Old Apr 20, 2006 | 11:08 AM
Wonk Unit's Avatar
Default drums to discs!
so i've got rear drum brakes on my 97 civic. would it be too hard/expensive to switch to rotors, and would it be worth it?? car is mainly used as a daily driver, but i'm getting into auto X. if its possible, any good brands??
Old Apr 20, 2006 | 11:24 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: drums to discs! (Wonk Unit)
Brands?
You have to swap your whole rear trailing arm assembly from a civic or integra with rear discs. Youll need the donor vehicles brake hoses too. It's always a good idea to do a complete brake job before you install them too. Brakes don't sit well in a junk-yard exposed to the elements...
You'll have to get e-brake cables from another car (search to find which ones fit your specific car). You'll also need a proportioning valve if you don't have a hatchback...
Old Apr 20, 2006 | 12:19 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wonk Unit &raquo;</TD></TR><TR><TD CLASS="quote">so i've got rear drum brakes on my 97 civic. would it be too hard/expensive to switch to rotors, and would it be worth it?? </TD></TR></TABLE>
no it wouldnt be worth it. you wont get any extra braking and itll only make the car heavier.
Old Apr 20, 2006 | 12:28 PM
nonsense's Avatar
Default Re: drums to discs! (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">no it wouldnt be worth it. you wont get any extra braking and itll only make the car heavier.</TD></TR></TABLE>
and since he's getting into autox it may place him in a higher class
Old Apr 20, 2006 | 02:09 PM
Wonk Unit's Avatar
so i guess its not worth it for the rears. what about replacing the front discs with somthing better?
Old Apr 21, 2006 | 06:42 AM
nonsense's Avatar
Default Re: (Wonk Unit)
Just replace the front pads with something better and run regular stock front disks
Old Apr 21, 2006 | 06:50 AM
92hatchattack's Avatar
how much weight is added when switching to rear disks.... sometimes i consider doing it just so i dont have to change the damn drum breaks anymore.... its a pain..
Old Apr 21, 2006 | 06:51 AM
^^ andhow much of it is rotaional mass???? I would figure the disksrotating would be lighter than the drums....
Old Apr 21, 2006 | 07:18 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (92hatchattack)
The exact weight difference has yet to be determined (as far as I've read).
From the looks, most of the material of the drum is located as far from it's rotational center as possible. This would make the discs easier to spin & stop...
Old Apr 21, 2006 | 02:40 PM
Wonk Unit's Avatar
Default Re: (94eg!)
so the most logical thing to do is just switch pads?? new slotted and cross drilled rotors wouldnt' help much more?? i see....
Old Apr 21, 2006 | 02:42 PM
Tyson's Avatar
most logical thing is to make sure your brakes are well maintained and have decent brake pads and fresh fluid and clean (plain) rotors.
Old Apr 22, 2006 | 05:55 PM
Wonk Unit's Avatar
Default Re: (Tyson)
sweet thanks a lot. any other advice/info would be apreciated!
VegasEg8
Suspension & Brakes
17
Jan 3, 2014 08:29 AM
pcorad
18
Apr 6, 2008 12:32 PM
LSVTEC 91 Civic
Honda Fit
37
Nov 15, 2007 05:52 AM
pootie.teng
22
Jul 12, 2006 07:27 PM
codyb13
Mar 25, 2005 10:22 AM
