type s k20a and jdm type r k20a - whats the diff??
hey guys
would any of you guys know the difference between the type s k20a and the jdm type r k20a? if there is any difference?
any help would be appreciated, thanks!
Type S
6 SPD
201hp @ 7800 rpm
140ft/lb @ 7000 rpm
11.0:1
8100 Redline
Ratios:
1st 3.267
2nd 2.130
3rd 1.517
4th 1.147
5th 0.921
6th 0.738
Reverse 3.583
Final 4.765
K20 R
6 SPD LSD Hydraulic
11.5
220hp @ 8000
158lbft @ 7000
8400 Redline
Ratios:
1st 3.27
2nd 2.13
3rd 1.57
4th 1.21
5th 0.97
6th 0.78
Final Drive 4.76
Not too keen on the K20's, but Im pretty sure there along the same lines as the difference between R and GSR motors.
I.E Pistons, cams, head flow, improved flow on header/exhaust system, etc.
Not sure why the question is asked, but if your thinking of a swap, go with the R motor.
6 SPD
201hp @ 7800 rpm
140ft/lb @ 7000 rpm
11.0:1
8100 Redline
Ratios:
1st 3.267
2nd 2.130
3rd 1.517
4th 1.147
5th 0.921
6th 0.738
Reverse 3.583
Final 4.765
K20 R
6 SPD LSD Hydraulic
11.5
220hp @ 8000
158lbft @ 7000
8400 Redline
Ratios:
1st 3.27
2nd 2.13
3rd 1.57
4th 1.21
5th 0.97
6th 0.78
Final Drive 4.76
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver comet »</TD></TR><TR><TD CLASS="quote">typeS - K20A2
typeR - K20A</TD></TR></TABLE>
05+ type-S = k20z1
Supposedly, the current -S has the same cams as the Type-R motor.
Things helping boost the ITR K20A are the higher compression and 4-2-1 header. I'd expect the ECU to be tuned a little more aggressively, too.
05+ type-S = k20z1
i believe the current S motors' cams are different p/n's from the R, but virtually identical otherwise.
my thoughts on hte swap, go with the k20a for hte "jdm poitns" whatever the expletive thats worth
for the saving in money, i think a k20a2 with type r tranny or even fd is a better idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :BoostedDC5: »</TD></TR><TR><TD CLASS="quote">k20a2 is better for boost
k20a if you plan to stay all motor</TD></TR></TABLE>
a boosted 11.0:1 CR motor?are you crazy?
k24a1 stock block & A2 head vs porsche GT2
http://videos.streetfire.net/v...5.htm
after the porsche got a stg 2 turbo upgrade
http://videos.streetfire.net/v...F.htm
21 psi 512whp stock block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _adirondackR_ »</TD></TR><TR><TD CLASS="quote">k24a1 stock block & A2 head vs porsche GT2
21 psi 512whp stock block </TD></TR></TABLE>
the guy filming in the second link sucks at filming, he can't hold still at all and doesnt know how to properly use the zoom. other than that, it looked like a close race in the second. in the first one, that hatch just whipps that porsche
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reborn »</TD></TR><TR><TD CLASS="quote">a better choice than the lower compress. k20a3 because of hte stronger internals. best k series to boost is the a2</TD></TR></TABLE>
The A3 internals are NOT stronger than the A2.
The Z1 cams are PRC cams, which means they are TypeR.
The K20A makes its extra 10 hp over the Z1 from a larger intake manifold, .5 higher compression, different exhaust manifold, freer flowing axle back exhaust, and a tune that is for 95 octane fuel with 300 more rpm redline.
