please help...
Alright question:
Is there a difference between the two ground pinouts on the ecu?
http://technet.ff-squad.com/wiring.obd2b.htm
^^ using that page as a reference, slots B2 & B10 are listed are grounds, is there a difference, is one the main ground and another for something else? Thanks..
Depending on what you need it for you could use it for anything, there just grounds. Usually i dont use them i just use body ground.
If you need to wire them up fine out exactly where they go and wire it accordingly.
