will 235/45/17 tires RUB on my lowered 93 EX?
Old Apr 19, 2006 | 08:25 PM
Marco93EJ's Avatar
Default will 235/45/17 tires RUB on my lowered 93 EX?
im lowered 2" front and back. let me know, thanks -- marc
Old Apr 19, 2006 | 08:28 PM
turnsignalandy's Avatar
Default Re: will 235/45/17 tires RUB on my lowered 93 EX? (Marco93EJ)
im lowered 1.9 in on my 97 ex sedan. Making tight turns i rub on my stock wheels and tires, 185/65/14, so im guessing your gona expletive up some tires and wheel wells. for 17 in wheels go for a 40 or a 35 series tire.and nothin bigger then a 215, IMO
Old Apr 19, 2006 | 08:29 PM
AutoXer's Avatar
Absolutely.
215 would be a stretch.
Old Apr 19, 2006 | 08:30 PM
94hatchling's Avatar
good god.... 235? thats HUGE for a civic. i'm running 205s, lowered at least 2" on 15s, and i rub.
Old Apr 19, 2006 | 08:35 PM
CBEengineering's Avatar
Default Re: (94hatchling)
i had a teg with 215 45 16 40mm offset got em off a non lowered mini cooper rota slips, put the omni powers on 2 in down and cut a tire before i got to the alignment shop
Old Apr 19, 2006 | 08:53 PM
ekcivic9's Avatar
i run 205/45/16s and i rub when i hit a dip or turn fast.
i had to roll the fenders in order for it to stop rubbing when ever i touched the wheel.
Old Apr 19, 2006 | 08:58 PM
Default Re: will 235/45/17 tires RUB on my lowered 93 EX? (AutoXer)
with 205/16/45 on my lowered civic(1.9in) should i be worried bout the height of the tire or the width? (rubbing)
Old Apr 19, 2006 | 09:02 PM
ekcivic9's Avatar
Default Re: will 235/45/17 tires RUB on my lowered 93 EX? (turnsignalandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">with 205/16/45 on my lowered civic(1.9in) should i be worried bout the height of the tire or the width? (rubbing)</TD></TR></TABLE>
do you know the offset?
my offset was weird, if you rub, first pull off the rubber trim inside the wheel well and see if it improves. if not, then you gotta roll.
Old Apr 19, 2006 | 09:07 PM
Default Re: will 235/45/17 tires RUB on my lowered 93 EX? (ekcivic9)
i think its 38 offset, thats what it says on the rota site for circuit 8s. Which overall size will be closer to stock, 16s with 45 or 40 series. Stock is 14 with 65 series
Old Apr 19, 2006 | 09:13 PM
ekcivic9's Avatar
well if you have your camber adjusted close to zero you may be more likely to rub.
but honestly, rolling the fenders isnt that hard at all.
Old Apr 19, 2006 | 09:44 PM
.Ry's Avatar
.Ry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">i think its 38 offset, thats what it says on the rota site for circuit 8s. Which overall size will be closer to stock, 16s with 45 or 40 series. Stock is 14 with 65 series</TD></TR></TABLE> On most civics you will want a 42-45 offset. 205/45/16 is whats called if your coming from a 185/65/14. To get as close as you can mess with this tire calculator.. http://www.miata.net/garage/tirecalc.html
1Tym
Aug 24, 2004 03:39 PM
JD95hatch
Aug 20, 2004 02:07 PM
happyman12
Feb 6, 2004 12:55 PM
Crxer
Oct 30, 2002 11:19 AM
vtecdc2
Sep 22, 2002 08:15 AM
