car wont start *part 2*
Old Apr 19, 2006 | 06:09 PM
sk8shorty012's Avatar
Default car wont start *part 2*
Well im back again,
If you guys remember a while back I had a thread about trying to start a turbo civic with some rx7 injectors.
Well... I picked up a set of dsm 390cc injectors and set the uberdata map for it. Wired em up correctly and everything, but the car STILL WONT START. Theres no CEL and the battery is charged. Im not sure what it could be, but the car has sat for 5 months, so any suggestions? Maybe the alternator is bad? What would be some signs?
Old Apr 19, 2006 | 06:46 PM
Rickcrx's Avatar
Did u check all the fuses in ur engine bay?I had almost the same problem on my GS-T and i replace the 50A fuse and the car start right up.Check the fuses and let us know.
Old Apr 19, 2006 | 07:15 PM
checked all the fuses..good.
Old Apr 19, 2006 | 09:19 PM
bump
Old Apr 19, 2006 | 11:42 PM
kr's Avatar
kr
Default Re: car wont start *part 2* (sk8shorty012)
did you put the ground wire from the harness to the t-stat housing?
Old Apr 20, 2006 | 06:39 PM
Default Re: car wont start *part 2* (kr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kr &raquo;</TD></TR><TR><TD CLASS="quote">did you put the ground wire from the harness to the t-stat housing?</TD></TR></TABLE>
what do you mean?
Old Apr 20, 2006 | 06:54 PM
ablock's Avatar
i have a 95 civic and i had a problem starting it. i had to replace my distributor.the car would turn but there was no spark. pull a spark plug wire out of the cover and a plug in it. in a dark room have someone just tap the ignition from inside the cara few times and u watch to see if theres any spark in the lines.if not i would replace the distrubutor.
Old Apr 20, 2006 | 07:01 PM
we have spark and air, we think its fuel, but theres no CEL. I think it has something to with a ground somewhere, thats what I was trying to figure out what kr was referring to in his post
Old Apr 20, 2006 | 07:35 PM
kr's Avatar
kr
Default Re: (sk8shorty012)
your engine harness ground goes here.
Old Apr 20, 2006 | 10:02 PM
care to go into detail on what you mean? sorry i just want to make sure i understand it all, im obd2 converted to obd1 btw..
Old Apr 20, 2006 | 10:06 PM
The Internet Tough Guy's Avatar
are you sure you're getting fuel?
take a squirt bottle, fill it with gas, open the throttle plate and spray it in there while a friend cranks it.
check for fuel, check for spark, check compression. once you have those 3 it will start.
Old Apr 20, 2006 | 10:08 PM
Default Re: (The Internet Tough Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Internet Tough Guy &raquo;</TD></TR><TR><TD CLASS="quote">are you sure you're getting fuel?
check for fuel, check for spark, check compression. once you have those 3 it will start.</TD></TR></TABLE>
yeah..on an updated note, its throwing cel 16, aka fuel system. Its gotta be something with the wiring, cause I know the injectors are physically in there correct...
Old Apr 20, 2006 | 10:11 PM
SHG_Beans's Avatar
what happens when you turn the key? im judging from the fact that you know you have spark that it cranks? check allllllll your grounds, my cousin left ONE off when we did his swap, and it wouldnt crank or anything, whatsoever. (it was from tranny to chassis by the way.
Old Apr 20, 2006 | 10:19 PM
ALLMOTA92EG's Avatar
You possibly could of wired the injector wires backwards.
Old Apr 20, 2006 | 10:21 PM
injectors are wired in correct (as far as I know), itll crank and crank and crank, but not turn over...could it be the main relay? (I hear the fuel pump come on though)
Old Apr 20, 2006 | 10:36 PM
this has nothing to do with the fuel system, but do a valve adjustment. if those are off enough it won't run. 0.007 intake and 0.009 ex. are magic numbers for vtec cams.
but first you really need to see if fuel is getting in there.
Old Apr 26, 2006 | 08:22 PM
SHG_Beans's Avatar
Sounds simple and stupid, but make sure your plug wires are on correctly. It happens, hehe
Old Apr 26, 2006 | 08:43 PM
scrappysofly's Avatar
if i was you i would locate a noid tester to test your injectors to make sure they are working
mhewitt
Oct 16, 2010 11:25 AM
Honda_wannabe
13
Jun 9, 2010 03:53 PM
kiklo16
Aug 3, 2007 06:46 AM
eurodeseo
Jan 5, 2006 03:21 PM
t0ekn3e
May 25, 2004 11:53 PM
