EG b16a into a ek WHat part do i need?
Old Apr 19, 2006 | 05:33 PM
siffredi's Avatar
Default EG b16a into a ek WHat part do i need?
conversion harness to start but what mounts what about shift linkage????
Old Apr 19, 2006 | 05:35 PM
G2 Speed's Avatar
Default Re: EG b16a into a ek WHat part do i need? (siffredi)
https://honda-tech.com/zerosearch
you will seriously find everything in there
Old Apr 19, 2006 | 05:39 PM
BlueIntegraBoy's Avatar
Use an Integra (or the one you are using in your EG) or Si shift linkage.
Driver side - Use driver side mount bracket from the 99-00 Si: 11910-P30-000. This piece bolts to the block below the cam gears. Reuse the civic studs. Also, use all other civic parts at this location.
Rear tranny - Use rear tranny mount from the 99-00 Si: 50827-S04-N10. Use the stock civic rubber mount.
AC Bracket - Use the ac bracket from CRV: 38930-P7J-000, and reuse the civic stud and rubber mount. Integra piece is similar but won't work.
Front tranny bracket - Use integra piece on the tranny but civic stud and rubber mount. Integra stud and rubber looks the same but won't work.
Upper tranny mount - Use all the civic pieces.
http://phear7imports.net/trey/6gen
Zx
Dec 13, 2006 07:53 AM
pinoyboy204
10
Apr 26, 2006 10:09 AM
atmosphere
Apr 19, 2006 02:30 PM
black-hatch
Apr 21, 2003 09:08 AM
Soku1kcivic
Apr 6, 2002 02:12 PM
