Need mechanical help with my swap ASAP(Columbia,SC)
I got a B16 swapped EG. I need someone to take a look at this and see why it wont crank. Motor turns over fine, no funny noises. Its got a new timming belt,tensioner,waterpump,headgasket. Motor is timmed correctly as far as I know. Getting fire to all four cylinders. I even installed new injectors today and same thing. It will not start. I need some help with this one. Can anyone local come give this thing a look over and maybe come up with something. I'm not asking anyone to fix for me, just to look it over and maybe be able to come up with the problem. Thanks....
JJ
JJ
Yep the fuel pump is working. I am getting fuel all the way to the injectors. I am also getting very good spark.
Cant get the car running to get any cells. Hell the check engine light works, because when I cut the car on it comes on and then goes off like it is supposed to do.
Still needing some help here. Hell I will buy the pizza and beer. Come on guys someone local has got to have an idea about what might be going on with my car.
The main possibilities are
- ground problem
- main relay
- ingitor
- coil
I'm guessing it's a ground problem
check the ground at the thermostat that's an easy one to forget.
I might be able to look at it some time....maybe saturday. I work at a shop that only works on Hondas. The boss/owner is amazing at figuring stuff like that out. I'm more of an apprentice.
Barnhill Automotive 772-5144 - Labor is $60/hour. Probably we could get it running within an hour
- ground problem
- main relay
- ingitor
- coil
toytroy
Sep 27, 2012 10:06 AM
blaxican05
Jul 2, 2006 02:09 PM
